MHB Solve for q: Q=p-q/2 q=p-2Q
  • Thread starter Thread starter OMGMathPLS
The discussion revolves around solving the equations Q = p - q/2 and q = p - 2Q. Participants clarify that both expressions, p - 2Q and -2Q + p, represent the same value due to the commutative property of addition. The process of isolating q involves manipulating the equations through multiplication and addition to achieve the desired form. The rationale for adding q - 2Q to simplify the left side to just q is emphasized as a key step in solving the equation. Overall, the conversation highlights the flexibility in expressing equivalent mathematical solutions.
OMGMathPLS
Solve for q:
Q=p-q/2
Correct answer :
p-2Q
or
-2Q+pHow can this answer be either p-2Q OR -2Q+p. I mean I can see they are the same value but how would you do it to get different answers?
Mathematics news on Phys.org
I assume you mean:
Q=(p-q)/2
or:
$$Q=\frac{p-q}{2}$$
Multiply through by $2$:
$$2Q=p-q$$
Add $q-2Q$ to both sides:
$$q=p-2Q$$
Now, let's go back to:
$$Q=\frac{p-q}{2}$$
Multiply through by $-2$:
$$-2Q=q-p$$
Add $p$ to both sides:
$$-2Q+p=q$$
The form you get (assuming you use valid operations), and/or choose to use depends largely on you. The commutative law of addition results in:
$$p-2Q=-2Q+p$$
Personally, I avoid the use of leading negatives whenever possible. :D
Thanks.Why did you add q-2Q to both sides?
Doing so resulted in the left side of the equation having just $q$ in it, which is what we want, as we are solving for $q$.. :D
Q=(p-q)/2
multiply both sides by 2 and the 2 on the right hand side cancels out
2Q=p-q
2Q-p=-q
you don't want to have -q so instead you want to end up with something for q. just flip the signs or multiply the whole thing by -.
-(2Q-p=-q)
-2Q+p=q
p-2Q is the same as p+(-2Q) and that's equivalent to -2Q+p in which both cases the the 2Q has a negative sign and the p has a positive.
hope that help! :o
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 19 ·
