MHB Solve for the angles in a triangle
  • Thread starter Thread starter gazparkin
    Angles Triangle
The discussion revolves around solving for the angles in an isosceles triangle. The user initially calculated x as 30 and y as 60, assuming the triangle's base angles were equal. After further calculations, they revised their values to x = 40 and y = 80, which was confirmed as correct by another participant. The equation used was 60 + x + 2x = 180, leading to the correct angle measures. The conversation highlights the importance of verifying calculations in geometry.
gazparkin
Hi,
Could someone check that I'm right with this one, or put me right! I've worked the value out as
x=30 and y (2x) = 60. I've come to this as I think it's an isosceles triangle so the base angles would be equal. Am I right?
Thank you!
Mathematics news on Phys.org
60 + x + y = 180
if y = 2x ...
60 + x + 2x = 180
try again ...
Is it x = 40 and y =80??
Yes, that's correct.
Thank you for your help.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
