MHB Solve linear algebra equation 2x – 1 = 9 – 3x
The discussion focuses on solving the linear algebra equation 2x – 1 = 9 – 3x, where the solution process involves isolating x. Initially, it is suggested to rearrange the equation, leading to -1 = 9 - 5x. After further manipulation, the correct solution is found to be x = 2. Additionally, another equation, 4(3b-1)+6=5(2b+4), is also solved, resulting in b = 9. The participants express appreciation for the clarity of the explanations provided.
gazparkin
Hi,
Could someone help me with this question:
2x – 1 = 9 – 3x
Thank you in advance!
Mathematics news on Phys.org
gazparkin said:
Hi,
2x – 1 = 9 – 3x
Sorry, there's another one that I'm stuck on too. Really interested to understand the working out on this.
4(3b-1)+6=5(2b+4)
gazparkin said:
Hi,
2x – 1 = 9 – 3x
Step 1: Get all the x's on one side: Subtract 2x on both sides:
2x - 1 - 2x = 9 - 3x - 2x
-1 = 9 - 5x
Now do the same with the numbers. Can you finish?
-Dan
- - - Updated - - -
4(3b-1)+6=5(2b+4)
Expand the parentheses:
4(3b - 1) + 6 = 5(2b + 4)
[math]4 \cdot 3b + 4 \cdot (-1) + 6 = 5 \cdot 2b + 5 \cdot 4[/math]
Now combine terms:
12b - 4 + 6 = 10b + 20
12b + 2 = 10b + 20
Now it's like your first problem. Can you finish?
-Dan
-1 = 9 - 5x
-Dan
- - - Updated - - -Expand the parentheses:
Now combine terms:
12b + 2 = 10b + 20
-Dan
Thanks Dan - makes this really clear. The first one I get x=4 and the 2nd one I get b=9.
The second one is okay. Let's take another look at the first one. I left off with
-1 = 9 - 5x
Now get the numbers:
-1 - 9 = 9 - 5x - 9
-10 = -5x
[math]\dfrac{-10}{-5} = \dfrac{-5x}{-5} [/math]
2 = x
-Dan
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
