Solve Physics Echo Problem: Air Echo Returns 1.33s Later
  • Thread starter Thread starter SpicyWassabi101
    Echo Physics
The discussion revolves around calculating the additional time it takes for an echo to return in air compared to water. The first attempt correctly determines that the echo in air takes 1.33 seconds longer to return, based on the speed of sound in both mediums. The second attempt misinterprets the problem by calculating the total time for the echo in air and then attempting to find a return time, leading to an incorrect conclusion of 0.465 seconds. Participants agree that the first method is accurate, clarifying that the question seeks the difference in total time, not the return journey. The consensus confirms that the correct additional time for the air echo is indeed 1.33 seconds.
SpicyWassabi101
A boat is floating at rest in dense fog near a cliff. The captain sounds a horn at water level and the sound travels through the salt water (1470 m/s) and the air (340 m/s) simultaneously. The echo in the water takes 0.40s to return. How much additional time will it take the echo in the air to return?
v = Δd/Δt
First Attempt:
v = Δd/Δt
Δd = v Δt = (1470 m/s) (0.40 s) = 588 m
Δt = Δd/v = 588m / 340 m/s = 1.73 s
Δt = 1.73 s – 0.40 s = 1.33 s
The echo in the air took 1.33 s longer to return.
Second Attempt:
I was thinking that 1.73 s would be the total time, so then I would have to divide 1.73 s by 2 to get the return time (0.865 s). Then I would subtract 0.40s from 0.865 s to get the additional time it took the echo to return, which would be 0.465 s. Like this:
v = Δd/Δt
Find total time:
Then find return time:
1.73 s/2 = 0.865 s
Then find additional time:
0.865 s - 0.40s = 0.465 s
The echo in the air took 0.465 s longer to return.
Please help me figure out which process is correct, if they even are correct :)
[/B]
pretty sure your 1st answer is correct. The question is not asking about the return journey, but total journey time - 0.4s in total for the underwater echo, so the question is looking for the difference in total time
Likes mfb
I am doing a similar qts
Likes SpicyWassabi101
Thanks so much for your help, mgkii :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
