Solve Plane Elasticity w/ Airy Stress Function
The discussion centers on challenges in solving plane elasticity problems using the Airy stress function method, particularly when introducing shear on two opposite sides. While uniaxial and biaxial tensions can be addressed with second-order polynomials, the addition of shear complicates the solution, leading to questions about the formulation of boundary conditions. It is noted that many elasticity problems may not yield "nice" polynomial solutions and often require numerical methods like finite element analysis. The participant expresses confusion over why simple tension allows for polynomial solutions while shear does not, suggesting that the problem may fall outside traditional mechanics of deformable bodies due to equilibrium issues. The conversation highlights the complexities of applying classical methods to certain boundary conditions in elasticity theory.
popbatman
Hello to everyone, I have a problem with the solution of plane elasticity problems with the method of Airy stress functions.
For instance I can solve a problem of uniaxial or biaxial uniform tension with a 2nd order polynomial, but if I add shear on only two opposite sides the problem seems to have no solution. Is it possible that I have to formulate the no shear boundary conditions (on the free shear sides) in a weak form? If so I cannot understand the mathematical reason for this. Someone can help me? thank you! (In the attached file a little sketch to clarify my question)
Is that no solution at all, or no "nice" solutions in the form of polynomials?
Often times, elasticity problems don't have "nice" solutions in terms of polynomials, but can be solved using numerical techniques. That's one reason why finite element and boundary element techniques are used.
I mean nice solution in polynomial form. What I cannot really realize is why simple uniaxial tension admits such a solution, while the application of uniform shear on two opposite sides does not!
In the third case, the body is not in equilibrium (unless some kinematic boundary conditions are applied), because it can rotate anticlockwise. In other words, this problem falls outside of the scope of the mechanics of deformable solid bodies. .
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
