MHB Solve Quadratic Equation: 3x²+12x+c=0
To determine the number of solutions for the quadratic equation 3x² + 12x + c = 0, the discriminant (D) must be analyzed. The discriminant is calculated as D = 12² - 4(3)c. For there to be one real solution, D must equal zero; for two real solutions, D must be greater than zero; and for two nonreal (complex) solutions, D must be less than zero. Solving the discriminant equation for c provides the specific values that correspond to each scenario. Understanding these conditions is essential for solving the quadratic equation effectively.
PhantomTechnic
Hello I've been stuck on this test review question for a few days, and I can't figure it out. Can someone help out?
"3x²+12x+c=0, Find solutions for c, where there is 1 real solution, 2 real solutions, and 2 nonreal(complex) solutions"
Mathematics news on Phys.org
Hello and welcome to MHB, PhantomTechnic! (Wave)
Let's review the quadratic formula:
Given the quadratic equation:
$$ax^2+bx+c=0$$
Then the solution is given by:
$$x=\frac{-b\pm\sqrt{b^2-4ac}}{2a}$$
Now, looking at that formula, what condition do we need for there to be only 1 solution?
$$ax^2+bx+c=0$$
Wouldn't it be when it equals zero?
When what equals zero? You are headed in the right direction, but I want to make certain you are talking about the correct expression...D
To answer Mark, D = 12² - 4(3)c, where D is the discriminant. What equals 0?
Solve for c. What do you get? It's probably not a prime number!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
