Solve Ratio Word Problem: Find Value of x
In summary, the problem involves finding the value of 'x' in a ratio problem where the work done by two groups of men in different amounts of time are given. The equation to solve is y(2x+1)(x-1) / y(2x+1)(x+4) = 3/10.
kuheli
hi ,
this is one simple math but i am not getting the answer.
the work done by (x-3) men in (2x+1) days and the work done by (2x+1)men in (x+4) days are in the ratio of 3:10.find the value of 'x'.
Mathematics news on Phys.org
Re: ratio
kuheli said:
hi ,
suppose the amount of work done by a man per day is y
(x-3) men done y(x-3) per day, and y(x-3)(2x+1) per (2x+1) days
Total work done by the first group is y(x-1)(2x+1)
In same manner the other group will do y(2x+1)(x+4)
we have to solve this equation
[tex]\frac{y(2x+1)(x-1)}{y(2x+1)(x+4)} = \frac{3}{10}[/tex]
Re: ratio
do you think the numerator of the fraction is
y(2x+1)(x-1) or y(2x+1)(x-3) ?
FAQ: Solve Ratio Word Problem: Find Value of x
What is a ratio word problem?
A ratio word problem is a type of mathematical problem that involves finding a missing value in a ratio or proportion equation. The problem will usually provide two known values and ask you to find the missing value, represented by x.
How do I solve a ratio word problem?
The first step in solving a ratio word problem is to identify the known values and the missing value represented by x. Then, use the given information to set up a ratio or proportion equation. Finally, solve the equation for x by cross-multiplying or using other algebraic techniques.
What are some common strategies for solving ratio word problems?
Some common strategies for solving ratio word problems include setting up a proportion equation, using equivalent ratios, and using the unitary method. It is also helpful to visualize the problem and break it down into smaller, simpler parts.
What are some tips for avoiding common mistakes when solving ratio word problems?
One common mistake when solving ratio word problems is misinterpreting the given information. Make sure to carefully read and understand the problem before attempting to solve it. It is also important to label the known values and the missing value correctly and to double-check your calculations.
How can I check my answer to a ratio word problem?
To check your answer to a ratio word problem, plug your solution back into the original equation and see if it makes the equation true. You can also use estimation to check if your answer is reasonable. If your answer is significantly different from the estimated value, you may need to recheck your calculations.
