Solve Simple Harmonic Motion Homework for Mass m on Spring s
A mass m is attached to a vertically suspended spring with stiffness s, stretching the spring by 0.0981m when at rest. When the mass is pulled down an additional 0.1m and released, it executes simple harmonic motion (SHM). The amplitude of the motion is determined to be 0.1m, while the constant phase angle (psi) is questioned for clarity. To find the period and other parameters, the spring constant k must be calculated, which relates to the mass and gravitational force. The discussion emphasizes the need to derive the spring constant and clarify the role of the initial extension in solving the SHM equations.
Lavace
A spring with stiffness s is suspended vertically with a mass m attached to it's free end. When the mass comes to rest the spring is found to have been stretched by 0.0981m. The mass is then pulled down a further 0.1m, released from rest and found to execute SHM.
We're given the general form of the SHM equation, i.e x(t) = Acos(wt + psi).
i) Calculate numerical values for the following: The amplitute, constant phase angle, frequency, period, maximum and minimum speed of the mass, the maximum kinetic energy for a mass of 1kg.
F =- kx
U = 1/2*kx^2
I don't particularly know where to start, or rather where I intended to start is incorrect.
I was thinking that we'd start off by calculating the spring constant (stiffness), k (called s in the script). But where this fits into finding the amplitude I'm not sure.
Is the amplitude just 0.1m (as that is where the mass was released).
What is meant by constant phase angle? Psi?
To find the period, we will have to know omega(0), which is equal to 2PI/T, where T is the period. Omega(0) is equal to k/m, but we don't know the mass, we could substitute in Newton II (F=ma), but I'm not sure where this will lead.
Any pushes in the correct direction is a massive thank you!
Can you find an expression for the distance by which a spring of stiffness s is stretched when mass m is attached to it?
So here's my new solution:
F = mg - kd - kx , where d is the extension the string was stretched by.
Because mg = kd (from the equilibrium balance), F = -kx
We can then say ma = -kx, and hence a = -(k/m)x, where w = SQRT(k/m)
But then, why were we given the extension of when the mass was placed on the spring? Was this to calculate the stiffness for the latter questions?
How will you find the amplitude?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
