Solve Skid's Friction Problem - Calculate Coefficient
  • Thread starter Thread starter sweetdaisy186
    Friction
Skid is driving at 80 mi/hr and needs to stop before hitting a wall 100 m away, prompting a calculation of the required coefficient of friction. The discussion focuses on the use of kinetic versus static friction, clarifying that if Skid does not lock his brakes, static friction is at play since the tires continue to roll without slipping. Participants emphasize the importance of converting speed from miles per hour to meters per second for accurate calculations. The conversation also highlights that mass cancels out in the equations, simplifying the process. Understanding the type of friction involved is crucial for solving the problem correctly.
sweetdaisy186
Hey guys! I think I have half of the question figured out
The question:
Skid is driving his car at 80 mi/hr. While reading the Springfield Reivedw of Books, he looks up and notices he is about to crash into a wall. When he is 100 m from the wall, he puts on the brakes. If Skid does not lock his brakes, calculate the coefficient of friction he needs so that he stops just before he hits the wall. What type of friction does he use?
My work:
I know that this involves kinetic friction. I thought I should calculate acceleration so that I can use the force equation.
I used the V^2 = V0^2 + 2a*delta X
I got an acceleration of 0.8. In order to use the SumFx = m*a equation, don't I need a mass so that I can somehow solve for the kinetic friction?
The question:
My work:
Just write down the equation with Newton's 2nd Law. You'll notice the mass will cancel out.
Hey!
I got my masses to cancel out, but I didn't get the right answer. I can't figure out what I did wrong. Here's my work it. :smile:
Convert 80 miles/hour to m/s!
Also: If he doesn't lock the brakes, the tires won't slip. What kind of friction is that? (Locking the brakes will cause you to skid.)
omg, I can't believe I didn't catch that. Thanks!
Wouldn't it be kinetic friction if he didn't lock his breaks?
No, just the opposite. Not locking the brakes means that the tires continue to roll without slipping--which means static friction. When you jam on the brakes, locking them (at least in the pre-ABS days) the wheels scrape along the ground instead of roll--that's when you get those cool skid marks, and kinetic friction applies. (And since under most conditions kinetic friction is less than static friction--giving you less control of the car--locking the brakes is a bad thing.)
OH! I see waht you mean, thanks!
