Solve Snell's Law Problem: Determine θ
  • Thread starter Thread starter haxxorboi
    Law Snell's law
To solve the Snell's Law problem regarding the angle θ for a fish looking up from 30 cm below the water's surface, the relevant equation is n1*sin(theta 1) = n2*sin(theta 2), with n1 as 1 (air), n2 as 1.33 (water), and theta 1 as 90 degrees. The calculations show that sin(90)/1.33 equals sin(theta 2), leading to sin(theta 2) = 1/1.33, which results in theta 2 being approximately 48.75 degrees. Initial attempts yielded incorrect values, but after reevaluation, the correct angle was confirmed. A clear mindset can help resolve such confusion in calculations.
haxxorboi
A fish is 30 cm below the surface of a lake.
If he looks up he can see the entire sky compressed in a cone of angle θ, because of refraction of light at the water surface. (θ is the angle between the cone axis and the cone surface.) Determine θ.
n1*sin(theta 1)=n2*sin(theta 2)
n1=1
n2=1.33
theta 1=90
theta 2=?
sin(90)/1.33=sin(theta 2)
sin-1(0.672177943)=42.24 degrees
This doesn't seem to be the answer though...
Any help?
i do it i get:
1sin90 = 1.33sin(theta 2)
1 = 1.33sin(theta 2)
1/1.33 = sin(theta 2)
.7518796992 = sin(theta 2)
sin-1(.7518796992) = 48.75 degrees
Man, what the heck was I doing? I did it again and I got the same answer as you, which is the correct answer...
I swear I just do things wrong 10 times in a row for no reason...
Thanks for the help!
no problem...i am the same way sometimes.
sometimes you just need a clear head to straighten it out.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
