Solve Spring Compression Problem: Work & Energy Approach
The discussion revolves around solving a physics problem involving a ball fired from a spring, using work and energy principles. The ball's mass is 0.1 kg, the spring constant is 50,000 N/m, and the spring is compressed by 2 m. The calculated height the ball should reach, assuming no friction, is approximately 102,038 m, which participants find implausibly high. For part B, the challenge lies in determining the frictional work done by air, with hints that the relationship between non-conservative forces and mechanical energy is key to solving it. The consensus suggests that the problem's parameters may be unrealistic, complicating the analysis of air resistance effects.
reklaws89
Use work and energy to solve the following. A .1 kg ball is placed against a massless spring that has a stretch constant 50,000 N/m and is compressed 2 m. The spring fires the ball straight up. a) How far did the ball rise assuming no friction? b) The ball's actual rise was 2m short of the answer in part A. What was the frictional work done by air?
1/2ky^2=mg(h+y)
I figured out part A to be 102,038 m... which seems outrageous, but the numbers in this problem are also outrageous. I'm really just struggling on how to do B or even attempt it.
You need to show some work to get help here. How did you end up with your answer in part a?
I used the equation (KE + PEg + PEs)i = (KE + PEg + PEs)f
KEi=0
KEf=0
PEgi=0
PEsf=0
PEsi=1/2ky^2
(y=compression)
PEgf=mg(h+y)
(h=distance traveled)
therefore, 1/2ky^2=mg(h+y)
so 1/2(50,000N/m)(4m)^2=.1kg(9.8m/s^2)(h+2m)
100,000Nm=.98N(h+2m)
102,040m=h+2m
102,038m=h
Looks correct, but as you say, the numbers given are outrageous. And if air friction causes the ball to stop 2 feet short of 102,038', that's not even significant enough to bother with. I think the problem just chose a poor set of numbers. But for part B, in general, what do you know about the relationship between work done by non conservative forces, and mechanical energy?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
