Solve the given differential equation
  • Thread starter Thread starter chwala
chwala
##(2xy+\cos y+\dfrac{2y}{x}-\sin x)dx +(x^2-y\sin y+1)dy=0##
hybrid ode
Ok, i just came up with this ode. How does one go about to solve it?
My attempt
Let ##M(x,y) =(2xy+\cos y+\dfrac{2y}{x}-\sin x)## and ##N(x,y) = (x^2-y\sin y+1)##
##\dfrac{\partial M}{\partial y}= 2x - \sin y + \dfrac{2}{x}## and ##\dfrac{\partial N}{\partial x}= 2x##
Not exact.
Say we have a point (x,y)=(x_0,y_0) on the solution, (x_0+\Delta x, y_0+\Delta y)
is also on the solution, where
\frac{\Delta y}{\Delta x}=\frac{dy}{dx}|_{x=x_0,y=y_0}=-\frac{2xy+\cos y+\frac{2y}{x}-\sin x}{x^2-y\sin y+1}|_{x=x_0,y=y_0}
In this way we can find successive solution points numerically. I have no idea how to get analytic solution if there is.
There's no guarantee that an ODE devised more-or-less at random will have an analytical solution.
Your approach of checking for exactness is a good start, but as you found, the equation isn't exact. Many textbooks on differential equations take this approach farther by making additional assumptions about the possible solutions.
@anuttarasammyak's suggestion of going for a numerical solution might be the only way forward here.
Likes anuttarasammyak
Thanks for the thoughtful input — actually, I’ve taken this as a personal challenge! I’ll be applying the Runge-Kutta method to this problem and working through it manually as far as possible. I’m also committed to generating more of these hybrid-style problems that push the boundaries of how we see mathematics, rather than sticking to traditional textbook paths.
Your suggestion of checking for exactness was solid, and even though it didn’t yield a direct solution here, it shows the right instinct. I completely agree with @anuttarasammyak — numerical methods may indeed be our best route for a meaningful solution. Let’s stretch the limits a little!
Likes anuttarasammyak and DeBangis21
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
