MHB Solve the inequality and graph the solution on a real number line
To solve the inequality (3x - 5)/(x - 5) > 4, first subtract 4 from both sides to obtain (3x - 5)/(x - 5) - 4 > 0. Next, combine the terms on the left side to create a single fraction. Identify critical points where the numerator and denominator equal zero, as these will help determine the intervals for testing the inequality. Finally, graph the solution on a real number line, marking the critical points and indicating where the inequality holds true.
megacat8921
How does one complete this problem?
Mathematics news on Phys.org
We are given to solve:
$$\frac{3x-5}{x-5}>4$$
Now, one might be tempted to multiply through by $x-5$ to clear the denominator on the right side, as we would with an equation. But with inequalities, we have to be mindful of the sign of a multiplicative quantity, so our best strategy here is to subtract 4 from both sides:
$$\frac{3x-5}{x-5}-4>0$$
Now, you need to combine terms on the left, and then determine your critical numbers, which are found anywhere the numerator AND denominator is zero. Can you proceed?
Yes, thank you.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
