Solve the problem involving toss of a biased coin- Probability
  • Thread starter Thread starter chwala
    Probability
The discussion focuses on solving a probability problem involving a biased coin using the Von Neumann strategy. The expected value is calculated as e = 1/p, leading to the conclusion that p = 2/3 after deriving the variance. The variance is expressed as Var(X) = (1-p)/p^2, which is confirmed through calculations. Additionally, the probability of getting a specific outcome, Pr(X=4), is computed as 2/81. The conversation highlights the connection to geometric distribution and explores alternative methods for deriving expected values and variances.
chwala
See attached
Probability -Expectation and variance
This is the problem;
My thinking on this is based on Von Neumann Strategy i.e
##e=pf+(1-p)((f+e)## where ##e##= Expected value, ##p##= Probability and ##f## = number of tosses ...in our case ##f=1##
##e=\frac{f}{p}=\frac{1}{p}## This is clear (as indicated on the left hand side of the ms -attached below).
The part that i need clarity is on the Variance derivation i.e on the right hand side of the ms solution.
I know that Variance=npq, with n=1 and q=1-p this part is clear...but i do not seem to get the highlighted part.
I just saw the steps...one has to know the derivation though...it stems from
##Var (X)= E[X^2]-(E(X))^2##.
The derivation of Variance is as shown on the attachment below;
From here the steps to solution is straightforward.
##Var(X)=\dfrac{1-p}{p^2}##
now in our problem we shall therefore have;
##\dfrac{1}{p}=2×\dfrac{1-p}{p^2}##
##p=2-2p##
##3p=2##
##p=\dfrac{2}{3}##
Something new i am learning here today...i can see that it all refers to the geometric distribution...for the next part of the question, it asks us to find;
Here we shall use,
##Pr(X=i)=(1-p)^{i-1}p##
given that ##p=\frac{2}{3}##
##Pr(X=4)=\left[\frac{1}{3}\right]^{3}×\frac{2}{3}=\frac{2}{81}##
Any other alternative approach or insight is highly welcome guys.
I would write <br /> p \sum_{k=1}^\infty k^2 (1-p)^{k-1} = \frac{p}{1-p} F(1-p) where <br /> F(x) = \sum_{k=0}^\infty k^2 x^k. Since multiplying by k inside the power series can be replaced by operating with x\frac{d}{dx} outside it we get <br /> \begin{split}<br /> F(x) = \left(x \frac{d}{dx}\right)^2\sum_{k=0}^\infty x^k &amp;= \left(x \frac{d}{dx}\right)^2\frac{1}{1-x} \\<br /> &amp;= \frac{x(x+1)}{(1 - x)^3}.\end{split} Thus <br /> \frac{p}{1-p}F(1-p) = \frac{p}{1-p} \frac{(1-p)(2-p)}{p^3} = \frac{2-p}{p^2} as required.
Another method is to note that:
$$E(X^2) = p + (1-p)E((X+1)^2)$$$$ = p + (1-p)(E(X^2) +2E(X) + 1)$$$$ = (1-p)E(X^2) +\frac{2-p}{p}$$Hence:
$$E(X^2) = \frac {2-p}{p^2}$$Note that we can justify the "trick" in the first line using power series:
$$E(X^2) = \sum_{k=1}^{\infty}k^2p(1-p)^{k-1}$$$$ = p + \sum_{k=2}^{\infty}k^2p(1-p)^{k-1}$$$$=p+ (1-p)\sum_{k=2}^{\infty}k^2p(1-p)^{k-2}$$$$ = p+ (1-p)\sum_{k=1}^{\infty}(k+1)^2p(1-p)^{k-1}$$$$= p + (1-p)E((X+1)^2)$$
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
