MHB Solve the triangle PQR by finding their angles
  • Thread starter Thread starter anemone
    Angles Triangle
In triangle PQR, angle bisectors QB and RA create angles QBA of 24° and RAB of 18°. To find the measures of angles P, Q, and R, the corrected angles must be used. The relationships between the angles can be established through the properties of angle bisectors. The calculations will yield the values for angles P, Q, and R based on the given information. The discussion highlights the importance of clarity in geometric notation for accurate problem-solving.
anemone
MHB
POTW Director
$QB$ and $RA$ are angle bisectors of the triangle $PQR$. Given that $\angle QBA=24^{\circ}$ and $\angle RAD=18^{\circ}$. Find the measure of each angles $P,\,Q$ and $R$.
Mathematics news on Phys.org
where is point D located ?
Ops...the question should read as "$QB$ and $RA$ are angle bisectors of the triangle $PQR$. Given that $\angle QBA=24^{\circ}$ and $\angle RAB=18^{\circ}$. Find the measure of each angles $P,\,Q$ and $R$."
The letter $D$ should be a $B$, my apologies for the confusion and that explains perfectly why this thread hasn't received any response yet!:o
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
