Solved Dynamics Question #3: Calculate Velocity, Momentum, and Force
  • Thread starter Thread starter looi76
    Dynamics
A ball with a mass of 0.20 kg is dropped from a height of 2.5 m and bounces back to 1.6 m, with gravity at 9.81 m/s². The velocity upon hitting the floor is calculated to be 7.0 m/s, while the velocity as it leaves the floor is 5.6 m/s. The change in momentum due to the impact is determined to be 2.5 kg·m/s. Additionally, the average force exerted by the floor on the ball during a 40 ms impact is calculated to be 63 N. The calculations and answers provided are confirmed to be correct.
looi76
[SOLVED] Dynamics Question #3
A ball of mass 0.20kg is dropped from a height of 2.5m and bounce back up to 1.6m. Taking the acceleration due to gravity as 9.81 ms^{-2}, calculate:
(a) the velocity of the ball as it hits the floor.
(b) the velocity of the ball as it leaves the floor.
(c) the change in momentum caused by the impact
(d) the average force of the floor on the ball if the impact time is 40ms.
v^2 = u^2 + 2as
Change in momentum = Final momentum - Initial momentum
Force = Change in momentum / Time
(a) v^2 = u^2 + 2as
v^2 = 0^2 + 2 \times 9.81 \times 2.5
v = \sqrt{2 \times 9.81 \times 2.5}
v = 7.0ms^{-1}
(b) v^2 = u^2 + 2as
v^2 = 0^2 + 2 \times 9.81 \times 1.6
v = \sqrt{2 \times 9.81 \times 1.6}
v = 5.6 ms^{-1}
(c) Change in momentum = Final momentum - Initial momentum
= mv - mu
= (0.2 \times 5.6) - (0.20 \times (-7.0))
= 2.5 kgms^{-1}
(d) Force = Change in momentum / Time
F = \frac{2.5}{40 \times 10^{-3}}
F = 63N
Are my answers correct?
Yes, they look good.
Thank you dx
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
