[SOLVED] Python - Issues Taking an Input as an Integer (or Converting It)
  • Thread starter Thread starter Ascendant0
    Integer Python
The discussion centers around a user's struggle with Python code for calculating the factorial of an integer input. The user initially encounters a TypeError due to attempting to concatenate a string with an integer in the print statement. Despite following online examples, the user is confused about why the input is stored as a string instead of an integer. They attempt to convert the input to an integer after receiving it, but face a ValueError because they mistakenly treat the variable name as a string. Eventually, the user realizes that the issue stemmed from not properly formatting the print statement, leading to the errors. They express frustration with the learning process and the lack of support from their professor, despite enjoying the course.
Ascendant0
TL;DR Summary
I'm trying to put together code that simply accepts an input of any number, calculates the factorial of the number, and then prints out the resulting value
This is one of the things I've tried:
Python:
import numpy as np
import matplotlib.pyplot as plt
import math
num = int(input("Enter an integer: "))
math.factorial(num)
print("The factorial of this value is " + num + ".")
And this is the resulting error message I get: TypeError: can only concatenate str (not "int") to str
I copied that int(input() code right off a site that explained how to do it, set it up identical to how they did, yet it still stores the input as a str instead of an int (and as such, of course can't calculate the factorial). So for some reason, the int() command isn't working for the input?
I also tried changing it to an int after the input was received with these changes:
Python:
string_value = "num"
integer_value = int(string_value)
math.factorial(integer_value)
print("The factorial of this value is " + integer_value + ".")
Again, I copied the suggestion on how to do it verbatim from a Python site, yet again, another error message: ValueError: invalid literal for int() with base 10: 'num'
There was a couple other things I tried that I can't even find again right now, but what is wrong here? I'm doing exactly what those sites are telling me to do to make the input an int, yet I continue getting some kind of error message or another, every single time???
Technology news on Phys.org
You guys can completely disregard this, I found my problem. I copied my code from another program, and completely forgot to remove the concatenations in the "print" line. Apologies, I am brand new to all of this as of a few days ago, and I feel the online materials are extremely convoluted and incomplete at times. We're all scrambling in this class, and the professor refuses to help us with any of our code. Wants us to all look it up ourselves. No idea why he even has office hours, but otherwise I really like him, and I love the course (Astrophysics lab)
Likes jedishrfu and berkeman
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
