Solving 2 Blocks on a Spring: Ma = Kx
  • Thread starter Thread starter eri139
    Blocks Spring
The discussion revolves around solving a physics problem involving two blocks on a spring, where the user initially miscalculated the effective mass by treating both blocks as one object. The user realized that the correct approach is to consider only the mass of the block being added to the spring system, which is 3 kg, rather than the combined mass of 5 kg and 3 kg. Despite this insight, the user still received an incorrect answer upon re-evaluation. Another participant suggested using the elastic potential energy equation, PE = (1/2)kx², equating it to gravitational potential energy, PE = mgh, as an alternative method to solve the problem. The conversation highlights the importance of precise calculations and understanding the physics concepts involved.
eri139
A 5 kilogram block is fastened to a vertical spring that has a spring constant of 1300 newtons per meter. A 3 kilogram block rests motionless on top of the 5 kilogram block.
a. When the blocks are at rest, how much is the spring compressed from its original length?
F = ma, F = kx
I honestly have no idea why I'm getting this question wrong, because it seems fairly straightforward.
I thought that treating the two blocks as one object would work, so 5 + 3 = 8. With Fg = Fs, ma = kx. Then, 8 x 9.8/1300 = x. x would be 0.06. That's been marked as an incorrect answer, though.
Thank you for any help!
edit: I got it! the issue was with preciseness, I didn't enter enough digits
well for (a), please forgive me if I am wrong, but I am visualizing the problem as if you placed the 3kg block on top of the 5kg spring system. Therefore, the original length was when the 5kg spring system had no extra weight and the compressed length was when you placed the 3kg block on top i.e. m = 3 not m = 5 + 3
I thought you had it for a moment! That would make a lot of sense. But unfortunately I just tried it and it's still incorrect :(
So sorry! As my last comment I feel as if working with the elastic potential energy equation
For springs: PE = (1/2)kx^(2) is worth a shot. Since PE Is also equal to mgh or mgx in this case. Keep on working hard! You got this!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
