Solving 3-D Dirac Delta Function Homework Question?
The discussion revolves around solving a homework problem involving a 3-D Dirac delta function integral. The integral in question is set within a solid sphere of radius 4, with a specific point defined by the vector \(\vec{r}' = 3\hat{x} + 2\hat{y} + \hat{z}\). The key equation used is that the integral of a function multiplied by the delta function evaluates to the function at the point where the delta function is non-zero. The participant initially struggled with substituting \(\vec{r}'\) into the function \(f(r) = r^2 - 2\vec{r} \cdot \vec{r}'\) but ultimately resolved the confusion. The discussion highlights the importance of understanding the properties of the Dirac delta function in evaluating integrals.
Dopplershift
\begin{equation}
\int_V (r^2 - \vec{2r} \cdot \vec{r}') \ \delta^3(\vec{r} - \vec{r}') d\tau
\end{equation}
where:
\begin{equation}
\end{equation}
Where d $\tau$ is the volume element, and V is a solid sphere with radius 4, centered at the origin.
I know the following:
Suppose:
\begin{equation}
\int_V f(r) \delta^3(\vec{r}-\vec{r}') d\tau = f(\vec{r'})
\end{equation}
(if r' is in the volume).
I'm just confused on how to plug in r' into f(r) which is
\begin{equation}
\end{equation}
Any help to get me started will be much appreciated.
Dopplershift said:
$$\int_V (r^2 - \vec{2r} \cdot \vec{r}') \ \delta^3(\vec{r} - \vec{r}') d\tau $$where:
$$\vec{r}' = 3\hat{x} + 2\hat{y} + \hat{z}$$ where ##d\tau## is the volume element, and V is a solid sphere with radius 4, centered at the origin.
First, write out your integral as an explicit triple integral.
Okay, so I can setup the integral.
\begin{equation}
\int_v (r^2 - 2\vec{r} \cdot \vec{r}') \delta_x(x-x_0) \delta_y (y-y_0) \delta_z (z-z_0) dx dy dz
\end{equation}
I guess I'm confused how I plug ##\vec{r}'## into f(##\vec{r}##)
Never Mind, I figured it out. I was overthinking the problem. Thanks for your help! :)
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
