Solving 4-log(3-x)=3: Is -10/3 the Answer?
  • Thread starter Thread starter wat2000
The equation 4 - log(3 - x) = 3 leads to the conclusion that log(3 - x) must equal 1 for the equation to hold true. By rearranging the equation, it is determined that 3 - x = 10, which simplifies to x = -7. The logarithmic function is confirmed to be the inverse of the exponential function, clarifying the steps taken to arrive at the solution. The initial claim of x = -10/3 is incorrect, and the correct answer is x = -7. This solution is validated through consistent steps found in precalculus resources.
wat2000
4-log(3-x)=3 i got -10/3. is this correct? and if it isn't can someone show me the steps?
That isn't what I am getting. What is the base for your logarithm? 10? Show us your steps so we can see what you are doing.
In order for this equation to be true, doesn't log(3-x) need to equal 1 ?
Now I am getting x= -7. The way i got that answer is like this. first i subtracted 4 from both sides. this gave me -log(3-x)=-1. Then i divided both sides by -1. This gave me log(3-x)=1. I am not really sure what this next step is but its what they did in the book. It just looks like they took the parentheses away from the 3-x and divided by base 10 or something, anyway this step makes the problem look like this: 3-x=10^1. Then i subtract 3 from both sides this gives me -x=7 I divide by -1 and this gives me x = -7. is this right? If its not where am i going wrong?These are the same steps the my precalc book use.
x = -7 is correct.
The step after log(3 - x) = 1 is not division. It uses the idea that the log function (base 10 in this case) is the inverse of the exponential function (10x in this case).
In symbols, this is log(x) = y <==> x = 10y
log(3 - x) = 1
<==> 3 - x = 101
or 3 - x = 10, so x = -7
Thanks I appreciate the help.
