Solving a Conceptual Question on Energy and Work
  • Thread starter Thread starter shahal
    Conceptual
shahal
I have a rather conceptual question, if I can understand it I can probably solve the prblem.
Here is the problem:
me and my equipment weight is w N. I am climbing a mountain and I climb an elavation of
h meters.
Now, my body convert 25% of energy burnt from fat into PE. The other 75% appears as heat. Half of the heat generated goes into evaporating sweat.
Also given are the following info:
fat contains 1000kcal/kg
and latent heat of evaporation of sweat is 2.5x10^6 j/Kg
mgh
wh
mL
ofcourse total work done to go up h meters = w x h J = wh Joules
what I do not understand is since 25% of fat burnt is converted into PE, does this mean
that this is equal to wh J?
or does it mean that 25% of wh is equal to the energy generated by burning fat?
Thanks in advance.
Basically I need to find out the amount of fat burnt.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
