Solving a Differential Equation: dy/dt to f(y,t)
coolxal
How do you change the form of a differential equation from dy/dt to f(y,t)? So if I had dy/dx = y/A(y) + 1 where A(y) is the area of a cross section of a conical base.
What are you asking exactly? Are you trying to solve your differential equation for y(x)?
To apply the Euler method, I'm given an equation of the form y' = y - t^2 + 1, 0 <= t <=2, y(0) = 0.5 and f(y,t) = y'. I set h = (b-a)/N where N is the number of iterations and h is the step size. t = a, w = y(0) then I loop w = w + h*f(t,w), t = a + i*h N times.
I'm trying to change an equation of the form (water flow rate) y&#039; = -0.6*\pi*r^2\sqrt{2g}\frac{\sqrt{y}}{A(y)} where r = 0.1 the radius of the orifice, g = 32, y(0) = 8, initial volume = 512(pi/3), A(y) is the area of the cross section of the tank x units above the orifice, into a form f(y,t) so I can apply the Euler method.
I think A(y) is supposed to be t but I don't know how to rewrite it to become t.
y=y(t), so A(y)=A(y(t)) is a function of t.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
