Solving a Differential Equation with Coefficients Linear in 2 variables.
In summary, the conversation is about solving a differential equation and finding the solution in a specific form. This involves rearranging the equation, using a translation of axes, and substitution to arrive at the final solution. The speaker also mentions struggling with the algebraic steps but eventually figuring it out.
Kiziaru
Solve the following equation:
[tex](2x-y)dx+(4x+y-6)dy=0 [/tex]
Solve for M and N as a linear system of equations; and
[tex]x_t = u + h [/tex]
[tex]y_t = v + k [/tex]
M = 2x-y=0
N = 4x+y-6=0
2x=y
4x+2x=6
6x=6
x=1
y=2 ∴ [tex]x_t=u+1 \\ dx=du [/tex]
[tex]y_t=v+2 \\ dy=dv [/tex]
Substitute:
(2(u+1)-(v+2))du+(4(u+1)+(v+2)-6)dv=0
(2u-v)dw+(4u+v)dv=0 ;Homogeneous of degree one
u=vw du=vdw+wdv
(2vw-v)(vdw+wdv)+(4vw+v)dv=0
Multiply out:
[tex]\frac{(2w-1)dw}{(2w+1)(w+1)} + \frac{dv}{v} = 0 [/tex]
Then partial fractions for the first term:
[tex]\frac{(2w-1)}{(2w+1)(w+1)} = \frac{A}{2w+1} + \frac{B}{w+1}[/tex]
Solved:
A=3 B=-4
Substitute A and B:
[tex]\frac{3dw}{2w+1} + \frac{-4dw}{w+1}+ \frac{dv}{v} = 0 [/tex]
Integrated:
[tex]3ln|2w+1|-4ln|w+1|+ln|v|=C [/tex]
My question: How exactly does the book get this answer: [tex](x+y-3)^3=c(2x+y-4)^2[/tex]Yes, I am bad at algebra.
First, you must re-arrange your differential equation in this form:
[tex]\frac{dy}{dx}=\frac{y-2x}{y+4x−6}=\frac{\frac{y}{x}-2}{\frac{y}{x}+4−\frac{6}{x}}[/tex]
Since the equation above is not a function of [itex]\frac{y}{x}[/itex] only, it is an inhomogeneous equation. Hence, we seek a translation of axes: x=X+h and y=Y+k
[tex]\frac{dY}{dX}=\frac{Y-2X+(k-2h)}{Y+4X+(k+4h-6)}[/tex]
[tex]k-2h=0
\\k+4h-6=0[/tex]
Solving the above system for h and k give: h=1 and k=2
So, we let x=X+1 and y=Y+2
[tex]\frac{dY}{dX}=\frac{Y-2X}{Y+4X}=\frac{\frac{Y}{X}-2}{\frac{Y}{X}+4}[/tex]
Since the above equation is now homogeneous, let [itex]\frac{Y}{X}=v[/itex]
Then, [tex]\frac{dY}{dX}=v+X\frac{dv}{dX}[/tex]
Solving, we get:
[tex]\ln X= -2v + \ln (v+2)^2 +\ln (v+1)^3[/tex]
[tex]2v=\ln \frac{(v+2)^2 (v+1)^3}{X}[/tex]
[tex]2\frac{Y}{X}=\ln \frac{(v+2)^2 (v+1)^3}{X}[/tex]
[tex]Y=\frac{X}{2} \ln \frac{(v+2)^2 (v+1)^3}{X}[/tex]
Finally, replace v, Y and X with the original y and x.
Solving, we get:
It's here that I am getting lost.
I have also have [tex]\frac{dY}{dX}=v+X\frac{dv}{dX}[/tex] and set it equal to [tex]\frac{v-2}{v+4}[/tex] but when I separate the variables I get [tex]\frac{(v+4)dv}{v^2+3v+2}=\frac{-dX}{X}[/tex]
Which does not integrate into something my textbook has.
Never mind, I figured it out. It only took me a day. :P
Also, thanks for everything. You were a huge help.
FAQ: Solving a Differential Equation with Coefficients Linear in 2 variables.
1. What is a differential equation?
A differential equation is a mathematical equation that relates a function with its derivatives. It describes the relationship between a function and its rate of change.
2. What does it mean for coefficients to be linear in 2 variables?
Coefficients are considered linear in 2 variables when they are multiplied by two or more variables and do not contain any exponents or other functions. This means that the coefficients are directly proportional to the variables, and the equation can be written in the form of y = mx + b.
3. How do you solve a differential equation with coefficients linear in 2 variables?
To solve a differential equation with coefficients linear in 2 variables, you can use the method of separation of variables. This involves separating the variables on each side of the equation and then integrating to find the solution.
4. What are some real-life applications of solving differential equations with coefficients linear in 2 variables?
Linear differential equations are commonly used in physics, engineering, and other sciences to model the behavior of systems. For example, they can be used to model the motion of objects, the flow of fluids, and the growth of populations.
5. Are there any limitations to solving differential equations with coefficients linear in 2 variables?
Yes, there are some limitations to using this method. It is only applicable to equations with linear coefficients, meaning that it cannot be used for non-linear equations. It also may not work for more complicated equations that cannot be easily separated into variables.
