Solving a Physics Homework Problem: Work, Distance, & Normal Force
The discussion revolves around solving a physics homework problem involving a block propelled by a compressed spring along a frictionless path, encountering friction and a loop-the-loop. The work done by friction is calculated using the equation W_f = μ_k m g L, representing energy lost between two locations. To find the distance the spring was compressed, conservation of energy principles are applied, leading to the equation x = √(2 U_0/k). For the normal force at the top of the loop, the kinetic energy is converted to velocity, and the normal force is expressed as F_N,top = (m v^2/r) - mg, with adjustments suggested for the calculations. The thread effectively addresses the application of physics principles to determine work, distance, and forces in a dynamic system.
funnyguy
A compressed spring is released pushing a block at rest along a level, frictionless path. This is Location 1. The block then passes over a small area of friction which ends and becomes frictionless again. This is Location 2. The block then enters a loop-the-loop in the shape of a circle under no apparent acceleration. The top of this loop is Location 3. The block then completes the loop, and continues to travel on a level, frictionless path towards a 90 degree arc which launches the block vertical to a point, Location 4.
Given is the mass of the block(m), coefficient of kinetic friction(\mu_k), length of the area with friction(L), the spring constant(k), diameter of the circular(D) loop-the-loop, height of the point Location 4(y).
a) Find the work done by friction.
b) Find the distance the spring was compressed.
c) Find the normal force at the top of the loop.
f_k = \mu_k m g
W = \vec{F} \Delta \vec{r}
K_i + U_i = K_f + U_f
K = \frac{1}{2} m v^2
U = m g y
U_s = \frac{1}{2} k x^2 - Hooke's law
\sum F_c = m a_c = \frac{m v^2}{r}
a) My current solution simply involves combining the friction force equation and putting that into the equation for work.
W_f = \mu_k m g L
This is the energy lost from Location 1 to Location 2.
b) Using conservation of energy, find the energy required to go from Location 2 to 4.
K_2 + U_2 = K_4 + U_4
K_2 = U_4 = m g y
Energy at Location 0 is equal to work done by friction between Location 1 and 2 and the potential energy at height y.
K_1 = K_2 + W_f
U_0 = K_1
x = \sqrt{\frac{2 U_0}{k}}
c) Converting kinetic energy to linear velocity, find the speed the block enters the loop.
r = \frac{D}{2}
K_2 = \frac{m v^2}{2}
v_2 = \sqrt{\frac{2 K_2}{m}}
F_{c,top] = \frac{m v^2}{r} = m g + F_{N,top}
F_{N,top} = \frac{m v^2}{r} - m g
I think I needed to change my part C calculation as K_2 = K_3 +U_3. Then solve for K_3 and then convert kinetic into velocity. So F_{N,top} = \frac{2 K_3}{r} - m g. I think that is the correct way to calculate it.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
