Solving a Quadratic Equation: Finding the Four Roots of Z⁴ + 4 = 0
becka12
the book asks to fnd the four roots of z to the fourth power + 4 = 0 and then use to demonstrate that z to the fourth power + 4 can be factored into two quadratics with real coefficinets. I am clueless on where to start. Please help.
start by setting z^4=-4 and solve for z taking the square root function twice (saving both roots)
Ok so I did what you said and then did the quadratic formula so i have 4 roots but how do I form quadratic formulas?
so let a,b,c,d be your roots. the general form of your equation can be written as (z-a)(z-b)(z-c)(z-d)=0. From that you can pick any two, multiply out and you'll have a quadratic ie: (z^2-bz-az+ab)(z-c)(z-d)=0. Since your roots are complex and you need real coefficients you might have to try different combinations
Let y= z2 so that you have a quadratic equation
y2+ 4= 0. What are the two solutions to that? Then, for each of the two values of y, set z2= y and take square roots.
Ok, I noticed something while playing with your equation, you can factor out z^4 + 4 = 0 into
(z^2 + 2i)(z^2 - 2i)
then
(z^2 + 2i) = (z + 1 - i)(z - 1 + i)
(z^2 - 2i) = (z + 1 + i)(z - 1 - i)
multiply
(z + 1 - i)(z + 1 + i) = z^2 + 2z + 2
(z - 1 + i)(z - 1 - i) = z^2 - 2z + 2
and there you have your two real number quadratics
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
