Solving a Thermodynamics Problem: Heating Water in a Piston-Cylinder
In summary, the conversation discusses a thermodynamics question involving a piston-cylinder containing 1kg of water in a 2-phase mixture. Heat is transferred to the water until it reaches a superheated state, with the piston keeping the pressure constant. The first law of thermodynamics is applied and the initial temperature is calculated using steam tables. The question then asks for the amount of heat needed to reach a saturated vapor state, which can be found using the enthalpy of vaporization of water at 100 kPa and multiplying it by the mass of water in the cylinder.
apamnani1
Hi guys,
Little stuck on the following thermodynamics question;
A piston-cylinder contains 1kg of water at 100kPa in a 2-phase mixture (liquid and vapour). Heat is transferred to the water by a resisance heater The piston is free to move and the cylinder is insultated. The water is heated until it is in a superheater state. The motion of the piston holds he pressure constant throughout the process.
A) write the first law of thermo applied (I have done this)
b) What is the initial temp (I have worked this out to be 99.6 degrees C using steam tables)
c) If the initial volume of the cylinder is 0.1m^3, how much heat must be transferred to the system to reach saturated vappour state? (STUCK HERE I tried to use Q = mcdeltat) :(
Any help would be greatly appreciated! Since the pressure is kept constant, you can use the enthalpy of vaporization to calculate the amount of heat required. The enthalpy of vaporization is the amount of energy required to turn a unit mass of liquid into a gas at constant pressure. So, you need to find the enthalpy of vaporization of water at 100 kPa and then multiply it by the mass of the water in the cylinder (1 kg). This will give you the total energy required to turn the liquid water into vapor.
Related to Solving a Thermodynamics Problem: Heating Water in a Piston-Cylinder
What is thermodynamics?
Thermodynamics is the branch of physics that deals with the relationships between heat, energy, and work.
What is a piston-cylinder?
A piston-cylinder is a device used to contain and manipulate a gas, typically by allowing the gas to expand or compress under pressure.
How do you heat water in a piston-cylinder?
To heat water in a piston-cylinder, the cylinder is first filled with water and the piston is placed on top. Heat is then applied to the cylinder, causing the water to expand and the piston to move, effectively heating the water.
What is the purpose of heating water in a piston-cylinder?
The purpose of heating water in a piston-cylinder is to study the thermodynamic properties of water under different conditions, such as temperature and pressure.
What factors affect the heating of water in a piston-cylinder?
The heating of water in a piston-cylinder is affected by factors such as the initial temperature and pressure of the water, the amount of heat applied, and the volume of the cylinder.
