Solving a Tricky Integral: 1/[3+e^(-x)]
  • MHB
  • Thread starter filiphenrique
  • Tags
    Integral
In summary, the integral $\displaystyle \int{ \frac{1}{3 + e^{-x}} \, dx }$ can be solved by making the substitution $u = 3e^x + 1$ and then using the formula $\displaystyle \int{ \frac{1}{u} \, du } = \ln{ |u| } + C$.
filiphenrique
Hi everyone, I had a test last week, and I couldn't solve this integral: 1/[3+e^(-x)]
How do I solve this one? Thanks in advance.
Try $u=3+e^{-x}$, so $u-3=e^{-x}$, and $du=-e^{-x} \, dx$. The integral becomes
$$-\int\frac{1}{u} \, \frac{du}{u-3}.$$
Can you take it from here?
Hi. I don't know if it's me that don't get what you've done, or if the the integral I wrote is clear. Here it is: View attachment 2392. The way you start solving is the same to this integral?
Yes, I assumed you started with
$$\int \frac{1}{3+e^{-x}} dx.$$
The $u$-substitution I outlined above will give you the new integral
$$-\int\frac{du}{u(u-3)}.$$
Can you proceed from here?
I'd probably do this:
$\displaystyle \begin{align*} \int{ \frac{1}{3 + e^{-x}} \, dx } &= \int{ \frac{e^x}{e^x \left( 3 + e^{-x} \right) } \, dx } \\ &= \int{ \frac{e^x}{3e^x + 1} \, dx } \\ &= \frac{1}{3} \int{ \frac{3e^x}{3e^x + 1} \, dx } \end{align*}$
Now make the substitution $\displaystyle \begin{align*} u = 3e^x + 1 \implies du = 3e^x\,dx \end{align*}$ and the integral becomes
$\displaystyle \begin{align*} \frac{1}{3} \int{ \frac{3e^x}{3e^x + 1} \, dx} &= \frac{1}{3} \int{ \frac{1}{u}\,du } \\ &= \frac{1}{3}\ln{ |u| } + C \\ &= \frac{1}{3} \ln{ \left| 3e^x + 1 \right| } + C \\ &= \frac{1}{3} \ln{ \left( 3e^x + 1 \right) } + C \textrm{ since } 3e^x + 1 > 0 \textrm{ for all } x \end{align*}$
FAQ: Solving a Tricky Integral: 1/[3+e^(-x)]
What is the general approach for solving tricky integrals?
The general approach for solving tricky integrals is to use various techniques such as substitution, integration by parts, or trigonometric identities to simplify the integral and make it easier to solve.
Can substitution be used to solve this integral?
Yes, substitution can be used to solve this integral. In particular, the substitution u = e^(-x) can be used to simplify the integral and make it solvable.
How do trigonometric identities help in solving integrals?
Trigonometric identities can be used to simplify integrals involving trigonometric functions. These identities can be used to rewrite the integral in a form that is easier to solve.
Can integration by parts be used to solve this integral?
Yes, integration by parts can be used to solve this integral. In particular, choosing u = 1 and dv = 1/[3+e^(-x)] allows us to simplify the integral and solve it using integration by parts.
Are there any other techniques that can be used to solve tricky integrals?
Yes, other techniques such as partial fractions, power series, and contour integration can also be used to solve tricky integrals. It is important to choose the most suitable technique based on the form of the integral.
