MHB Solving a Trigonometric Equation for Cos (x)
The discussion centers on solving the trigonometric equation 2cos(x) + 5sec(x) = 1.1. A participant initially misapplies the equation, leading to confusion over the correct formulation and resulting in a negative discriminant. Clarifications reveal that the original equation was misquoted, affecting the calculations. The correct approach involves rewriting the equation in quadratic form, allowing for the application of the quadratic formula. The conversation emphasizes careful transcription of equations to avoid errors in solving trigonometric problems.
melissax
Hi, may you help me?
I have a question I solved but couldn't ended.
If cos(x)+5Sec(x)=1.1 then Cos(x)=?
2Cos(x)+5Sec(x) =11/10
2Cos(x)+5/Cos(x)=11/10
2Cos(x)*Cos(x)+5=11/10*Cos(x)
2Cos^2(x)+5=11/10*Cos(x)
2Cos^2(x)-11/10-Cos(x)-5=0 then i used delta=b^2-4ac
then i found delta=-4.79
X1=-b+sqrt(delta)/2a
then i found x1=2.19 and x2=-b-sqrt(delta)/2a but as i learnd answer is 0.5 where is the my mistake? Thank you
Mathematics news on Phys.org
In-between these two lines, you have copied incorrectly. Where is the 2 coming from? Is that in the original problem or not?
You have made another error here: $(11/10)\cos(x)$ became $(11/10)-\cos(x)$.
You need to be more careful when you go from one line to the next. Pretend someone's holding a gun to your head and will fire if you make a mistake!
For the original problem, I get complex values for $\cos(x)$. Can you please post the original problem verbatim?
question is "2cos(x)+ 5sec(x)=1.1" problem isn't wrong.
Correct but can you help to solution?
In your original post you wrote the problem as "cos(x)+5Sec(x)=1.1" then you switched the "cos(x)" to "2cos(x)" on the next line. We can't tell if this is a math mistake which we need to explain or just a typo. I'm going to guess it's a typo.
[math]2\cos(x)+5\sec(x)=1.1[/math]
Multiply everything by $\cos(x)$ and you get
[math]2\cos^2(x)+5=1.1\cos(x)[/math] or [math]2\cos^2(x)-1.1\cos(x)+5=0[/math]
This has a quadratic form to it. Let $u=\cos(x)$ and rewrite the above equation as
[math]2u^2-1.1u+5=0[/math]
Can you make progress from here?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
