Solving an Electrical Problem: Why is the Answer Not 2s?
  • Thread starter Thread starter john merrick
    Electrical
The discussion centers on a misunderstanding of time calculations in electrical circuits. The initial calculation of 2 seconds for 1 Coulomb of charge is incorrect because it does not account for the energy involved. The book's equation, E=VIt, correctly indicates that 120J of energy dissipates over 20 seconds at a current of 0.5A. This suggests the problem is asking for the time to dissipate energy rather than the time for a specific amount of charge to pass through a circuit. Overall, the question's wording is considered vague, leading to confusion about the relationship between charge, energy, and time in electrical circuits.
john merrick
the charge passing through a circuit has 120J of energy. if the circuit is connected to a 12V battery and the current in the circuit is 0.5A how long does it take one coulomb of charge to pass through the circuit?
E=VIt
I=Q/t
i did this
t=Q/I 1C/0.5A =2s
the book says
E=VIt 120J=12v x 0.5A x t
t=20s.
i don't understand why the answer is not 2s.
Well the problem statement seems a bit vague to me. If I interpret "the charge passing through a circuit has 120J of energy" as that the energy given from the battery to a certain amount of charge that travels one loop of the circuit is 120J, then your book is correct.
Your own calculation finds the time needed for 1 Coulomb of charge to pass through a cross section of the circuit, not through 1 loop of the circuit.
Likes john merrick
john merrick said:
i did this
t=Q/I 1C/0.5A =2s
Notice that this equation doesn't include the given amount of energy, which is a clue that it's probably not what you're looking for. If I told you the energy was 240 J instead of 120, this equation would give you an identical answer for both.
Since the question involves both energy and time, that's a big clue that you're looking for something that includes power in it, which your book's equation does (the V*I portion).
Still, the question is poorly worded in my opinion. I can't remember ever discussing the time taken for an amount of charge to pass through a circuit in my basic electronics electric circuits class. A 0.5 amp current passes 10 coulombs of charge through each point in the circuit over 20 seconds (assuming a simple series circuit), so I don't understand what the question is talking about when asks about how long it takes for 1 coulomb to pass through the circuit.
What the book's answer really tells me is that it's looking for how long it takes to dissipate the 120 J of energy, not how long it takes for some quantity of charge to move through the circuit.
Likes john merrick
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
