MHB Solving an Integral with a Right Endpoint Riemann Sum
The discussion focuses on solving the integral of the function f(t) = 1 from x to x^2 using the right endpoint Riemann sum. It establishes that the integral can be expressed as the limit of a sum, leading to the conclusion that the integral equals x^2 - x when x is less than x^2. For cases where x equals 0 or 1, the integral evaluates to 0. If x^2 is less than x, the integral is redefined as the negative of the integral from x^2 to x, confirming that the result remains x^2 - x for all real x. The analysis provides a comprehensive understanding of the integral's behavior across different intervals.
Fernando Revilla
MHB
I quote a question from Yahoo! Answers
Turn the integral to a limit of the right endpoint Reimann sum?
1dt from x to x^2
I have given a link to the topic there so the OP can see my response.
Mathematics news on Phys.org
In general, consider the interval $[a,b]$, and the partition
$$a,a+1\frac{b-a}{n},a+2\frac{b-a}{n},\ldots,a+n\frac{b-a}{n}$$
Then,
$$\int_a^bf(t)dt=\lim_{n\to +\infty}\sum_{k=1}^n\frac{b-a}{n}f\left(a+k\frac{b-a}{n}\right)$$
In our case $f(t)=1$ so,
$$\int_a^bf(t)dt=\lim_{n\to +\infty}\sum_{k=1}^n\frac{b-a}{n}=\lim_{n\to +\infty}
(b-a)=b-a$$
That is, $\displaystyle\int_x^{x^2}1dt=x^2-x$ (if $x<x^2$).
For $x^2-x=0$ i.e. $x=1$ or $x=0$ the integral is $0$. If $x^2<x$, use $\displaystyle\int_x^{x^2}1dt=-\displaystyle\int_{x^2}^{x}1dt$
Hence, $\displaystyle\int_x^{x^2}1dt=x^2-x$ for all $x\in\mathbb{R}$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
