Solving Collisions with angles problem
  • Thread starter Thread starter AceInfinity
    Angles Collisions
The discussion focuses on solving a physics problem related to collisions using the conservation of momentum. The initial momentum is identified as being directed to the right, and the user plans to break down the momentum into X and Y components for analysis. Calculations show the momentum of one object (puck 1) as 1.2 kg•m/s and the other (puck 2) as 0.416 kg•m/s in the horizontal direction. Suggestions are made to simplify the problem by considering components in the Y direction or the final direction of puck 2 to streamline the calculations. The conversation emphasizes the importance of correctly applying vector equations in momentum conservation problems.
AceInfinity
First off, i'd like to note that this isn't homework, and I've seen other threads in here that deal with question/equation/problems, so I hope this isn't against the rules. I found this on a practice physics test online. I'm just using it for the benefit of my knowledge, nothing more.
I can provide the link if necessary for proof.
Heres the question I want to know how to solve:
[PLAIN]http://k.min.us/ibDXoi.jpg
ohhh... I think you put me on the right track for beginning to solve this. The initial momentum was
in this case. Therefore the conservation of momentum is seen for that X component, I'll have to split them off into the X and Y components of momentum and look specifically at the X/horizontal component of momentum to use the conservation of momentum, if I'm not mistaken?
4.85 Cos(36o) = 3.92m/s
p = mv
p = (0.200kg)(3.92m/s)
p = 1.2kg•m/s
Solve for momentum of that object.
p = mv
p = 0.784kg•m/s
Momentum of the other object (puck 2) is: 1.2kg•m/s - 0.784kg•m/s
= 0.416kg•m/s [Important: in the x/horizontal direction. need to solve for the angle'd direction]
0.416kg•m/s ÷ [cos(54o)] =
0.707741472...kg•m/s !
I think with "their" answer, they rounded a bit too early.​
Hi AceInfinity! :smile:
0.416kg•m/s / [cos(54o)] =
yes that's fine :smile:
but there are quicker ways of doing it …
you could take components in the y direction or in the final direction of puck 2 …
(both are quicker because they reduce the number of terms)
try both of those :wink:
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
