Solving Coupled ODEs with 4th Order Runge-Kutta Method
  • Thread starter Thread starter Dr. G
    Coupled
Dr. G
Can a 4th order Runge-Kutta method be used to solve an equation of this form:
dVx/dt = ωVy , where ω = constant. and Vx and Vy are the x and y components of the velocity.
That's not much of an equation to solve, as the right-hand-side is constant. You would need an equation for Vy also.
The equation for Vy is
dVy/dt = - ω Vx. And I have the I.C's. So, I can uncouple them. But if the magnetic field is more complicated, hence making ω more complicated, then I would like to see if I could use an
RK4 method to solve them. (These equations arise from the Lorentz force equation.)
Yes, RK is then a good choice.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
