MHB Solving Cubic Equation: x^3 - kx + (k + 11) = 0
  • Thread starter Thread starter Taran1
    Cubic
The cubic equation x^3 - kx + (k + 11) = 0 has integer solutions for k when k > 17 or k < -11. To determine the integer values of k that yield at least one positive integer solution for x, it is established that k can be expressed as k = (n^3 + 11) / (n - 1), where n is a positive integer. For k to be an integer, n - 1 must be a factor of 12, leading to possible values of k being 19, 25, 34, 59, and 184. This analysis confirms the initial findings and provides a clear algebraic method to derive the solutions. The discussion highlights the importance of understanding the relationship between the factors of the equation and the integer solutions for k.
Taran1
Hi, this question was in a year 11 extension maths textbook in the enrichment section. I have the answer as k>17 and k<-11 because I graphed it on GeoGebra. The Graph can be found here: https://ggbm.at/xpegwwtq. While I know the answers I would like to know how to work it out using algebra.
Here is the Question:
Consider the cubic equation x^3 - kx + (k + 11) = 0, find all the integer values of k for which the equation has at least one positive integer solution for x
Thanks, Taran
Mathematics news on Phys.org
Thanks, Taran
Hi Taran, and welcome to MHB.
If $x=n$ is a positive integer solution of the equation, then $n^3 - kn + k + 11 = 0$, so that $$k = \frac{n^3+11}{n-1} = \frac{(n-1)(n^2+n+1) + 12}{n-1} = n^2+n+1 + \frac{12}{n-1}.$$ For that to be an integer, $n-1$ must be a factor of $12$. You can then tabulate the possible values of $n$ and $k = \frac{n^3+11}{n-1}$, as follows: $$ \begin{array}{c|cccccc} n-1&1&2&3&4&6&12 \\ n&2&3&4&5&7&13 \\ k&19&19&25&34&59&184 \end{array}.$$ So the only possible values for $k$ are $19,\ 25,\ 34,\ 59,\ 184$ (which all agree with your condition that $k>17$).
Hello, Chris! (Wave)
This question was posted on another site, and I found your reply so insightful, I took the liberty of posting it there, for the benefit of several there trying to solve it. :)
Hi, Thank you so much! This question had my class stumped. That answer makes so much sense. It's been bugging me for a while and I'm very thankful for your help.
Thanks again, Taran
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
