Solving Electrolysis Questions: NaBr(aq) & Comparing Eo Values
When NaBr(aq) is electrolyzed using inert electrodes, there are differing opinions on the products formed at the anode and cathode. At the cathode, hydrogen gas (H2) is consistently identified as the product. The debate centers around the anode, where one answer suggests bromine gas (Br2) is produced, while another claims that oxygen gas (O2) and water (H2O) are formed. The discussion references standard electrode potentials (Eo values) to justify these claims, particularly focusing on the oxidation reactions at the anode. The Eo values for bromine and oxygen are compared to determine which reaction is more favorable. The argument against the formation of hydroxide ions (OH-) at the anode is based on the low equilibrium concentration in an aqueous NaBr solution, suggesting that the production of OH- is negligible. This leads to questions about the appropriateness of the equations used for comparison and the expected products in the electrolysis process.
Thevanquished
Here is the question:
Predict the products formed at the anode and at the cathode when NaBr(aq) is electrolysed using inert electrodes
Answer:
Somehow i got 2 different answers by different answer sheets
One of them stated that Br2 gas (anode) and H2 gas (cathode) would be liberated
However, the other one writes H2(cathode) , H2O and O2 (anode) are formed
There is no arguments for the products formed at the cathode as clearly it is H2 gas which is liberated there. However, the question lies in the products formed at the anode. Which one is correct?
Eo values if needed:
Br2 + 2e ::equil:: 2Br- Eo= +1.07V
Na+ + e ::equil:: Na Eo= -2.71V
O2 + 4H+ + 4e ::equil:: 2H2O Eo= +1.23V
O2 + 2H2O + 4e ::equil:: 4OH- Eo= +0.40V[/color]
2H2O + 2e ::equil:: H2 + 2OH- Eo= -0.83V
The ones in red are the equations in question. Which one should i use to compare Eo values with Br at the anode (oxidation)? And why?
The answer which states that bromine gas is liberated is most probably the right one (as it is provided by my school) but it used the O2 + 4H+ + 4e ::equil:: 2H2O equation to compare instead of O2 + 2H2O + 4e ::equil:: 4OH- why is this so?[/color]
Chemistry news on Phys.org
Where would you get your "4OH-" from in an aqueous solution of NaBr? The equilibrium concentration of it from the self-ionisation of water is going to be very insignificant and negligible (hence E value of the half-cell would be very positive actually, since equilibrium position lies very far to the right)
Aren't OH- ions produced in the cathode?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
