Solving equations with greatest integer function
To solve equations involving the greatest integer function, it's essential to understand how it operates. For example, if you have the equation 99 = [2x+1]/3, you can multiply both sides by 3 to isolate the greatest integer function, leading to [2x+1] = 297. This implies that 297 ≤ 2x + 1 < 298, which can be simplified to find the range for x as 148 ≤ x < 148.5. The discussion emphasizes the importance of recognizing the boundaries set by the greatest integer function to solve such equations effectively. Understanding these principles allows for accurate solutions to similar problems.
Bea77
I can't find a step by step explanation for solving these types of equations
eg.
99 = [2x+1]/3
eg.
99 = [2x+1]/3
or
48 = 4[2x/3]
How do you handle the multipliers iand constants inside the brackets?
thx
3. The Attempt at a Solution
Think about how the greatest integer function works. For example,
<br /> \lfloor 3.2 \rfloor = \lfloor 3.582 \rfloor = 3<br />
and in fact, if 3 \le x &lt; 4 it is true that
<br /> \lfloor x \rfloor = 3<br />
So, if you know that
<br /> \frac{\lfloor 2x+1\rfloor}{3} = 99<br />
you also know that
<br /> \lfloor 2x+1 \rfloor = 297<br />
(the 3 in the denominator is not in the function). What does the final
statement above tell you about how large 2x + 1 must be?
you also know that
so 297 <= 2x+1 < 298
296 <=2x and 2x < 297
148 <=x and x < 148.5
Did I get it?
Yup.
statdad said:
Yup.
Thanks!
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
