A Solving Euler's Principal Axis for Rigid Bodies
Euler's differential equations for rigid bodies yield angular acceleration and velocity, but integrating angular velocity is complex, leading to the representation of attitude as a product of an angle and a principal axis. Concerns arise regarding the assumption that the principal axis remains fixed over time, suggesting it should also change. The discussion highlights that angular velocities can be represented by vectors, despite angles not commuting under addition. The assumption that angular velocity is parallel to the principal axis simplifies the analysis, aligning with the transport theorem. Ultimately, the approach leads to a valid solution, confirming the assumptions made in the lecture.
kiuhnm
When we solve Euler's differential equations for rigid bodies we find the angular acceleration ##\dot{\boldsymbol\omega}## and then the angular velocity ##\boldsymbol\omega##. Integrating ##\boldsymbol\omega## is less straightforward, so we start from a representation of the attitude, take its derivative and equate it to ##\boldsymbol\omega##.
The attitude can be represented as ##\boldsymbol\gamma=\phi\hat{\boldsymbol e}##, where ##\hat{\boldsymbol e}## is the principal axis of the rotation. In a course I'm watching online, the professor computes the derivative of ##\boldsymbol\gamma## as follows:$$
\dot{\boldsymbol\gamma} = \dot\phi \hat{\boldsymbol e}
Wouldn't that be correct only for a fixed ##\hat{\boldsymbol e}##? Shouldn't we assume ##\hat{\boldsymbol e}## is changing in time as well?
That sure bothers me... angles cannot generally be represented by vectors because they do not commute under addition!
(But they do commute differentially, and so angular velocities can be represented by (pseudo-)vectors.)
I’ve never heard of “the” principle axis... only the principle axes (plural). Perhaps you’re thinking about an object with an axis of symmetry, like a top? Maybe you could link the lecture video so people have more context.
You're probably thinking about the eigendecomposition of the inertia matrix. This is something unrelated to that.
Here's the lecture:
It turns out we're assuming that ##\boldsymbol\omega## is parallel to the principal axis ##\hat{\boldsymbol e}## so, by the transport theorem, the inertial derivative is equal to the derivative wrt the frame ##B##. Time to watch the lecture again to see how this assumption is justified.
The lecture is split in short videos. Here's the video with the playlist:
h t t p s://www.youtube.com/watch?v=KQ6jEPe97co&index=1&list=PLCheZLRn7G_yaRHqMjcZrpxzEB8ZUXtjJ
edit: I had it backwards. By making the assumption that ##\dot{\boldsymbol\gamma} = \boldsymbol\omega## either we come to a contradiction or we find a solution which respects that assumption. In this case, everything works out just fine.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
