Solving for Angles of Tension Homework
  • Thread starter Thread starter IncognitoSOS
    Angles Tension
The discussion focuses on solving a physics problem involving three equal weights connected by strings in equilibrium. Participants emphasize the importance of drawing a free body diagram to analyze the forces acting on the system. The initial assumption that angles can be set at 45 degrees is challenged, with a reminder that vertical components must be balanced accurately. The need for clarity in the problem statement and visual aids is highlighted to facilitate understanding. Properly applying the equations and avoiding assumptions is crucial for finding the correct angles of tension.
IncognitoSOS
Three equal weights, two of them connected to the third by individual strings. If the mechanism is in equilibrium, what are the angles of the strings.
EFi=ma
T1=W
so 2T1=t2 = t1
T1=1/2W
So what now?
Your problem statement is not very informative. Connected how by individual strings? Is there a picture that goes with this?
Yes, but I don't know how to post it. In essence it is the letter M (with the left, right, and middle being the blocks, and the corners being the massless pulley system. However the only difference is that the center block is attached to a string and that string is what connects it to the other two strings. Think of a M with a Y for the inside (I know that's poorly worded, but I can't think of any other way to explain it.)
You have described it well enough. You need to draw a free body diagram of the "crotch" of the Y and say that the net force on it is zero. There are three forces but remember to add them as vectors. You can say that T1 = W for the bottom force, but it's the vertical components of T2 and T3 that add up to balance T1.
And since the weights of the side blocks are the same as the weight on the center block, we could assume that the angles are 45 degrees each (representing one half of the total weight?
No, we cannot assume that. As I said before, you need to draw a free body diagram and balance the vertical components. Cutting corners is dangerous. See what comes out of the equations.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
