Solving for Normal Modes in a Non Similar Coupled Pendulum
  • Thread starter Thread starter aseylys
    Coupled Pendulum
The discussion revolves around finding the normal modes of a coupled pendulum system with two different masses. The user struggles with the equations of motion due to the differing masses, initially deriving coupled differential equations but encountering sign errors. Clarifications are provided regarding the nature of normal modes, emphasizing that both masses oscillate at the same frequency, despite their mass differences. The importance of substituting assumed solutions into the equations of motion is highlighted to determine normal mode frequencies. The conversation concludes with a suggestion to explore a simulation tool for better understanding of the system's dynamics.
aseylys
(The picture is having trouble being directed so I attached it)
Hey guys, I'm trying to figure out the normal modes of a pendulum with two different masses. The lengths of the strings are the same and the weight of the strings are negligible.
I can easily find everything if the masses are equal but when the masses are different it kind of screws me up.
F=ma
Fs=k(x1-x2)=kΔx
m1*a1=-m1*g*(x1/l)-kΔx
m2*a2=-m2*g*(x2/l)-kΔx
x(double dot)n=an
Working it all out I get:
a1+a2+(g/l)*(x1+x2)+Δx((k/m1)-(k/m2))
This doesn't help me get a simple solution like x(t)=A*cos(ωt+\phi) because of the addition of the Δx((k/m1)-(k/m2))
Hello.
OK, so you have two coupled differential equations:
I think you have one sign error in these equations if Δx stands for the same quantity in both equations. (You didn't state what Δx means. Correction: You did state that Δx is x1-x2. Can you see which of the equations has a sign error?) If the spring exerts a negative force on one of the masses, will it also exert a negative force on the other mass?
You're going to try to find normal mode solutions in the form
x1 = A1cos(ωt + ##\phi##)
x2 = A2cos(ωt + ##\phi##)
Rather than add the two differential equations, try solving them simultaneously for A1 and A2 and see what happens.
Oops, I did miss a negative. So it'd be
m2*a2=-m2*g*(x2/l)+kΔx
Ploughing through it and setting some constant (I'm going to pick \eta) \eta=mn*xn
And using \omegag,n2=(g*mn)/l
So then:
\eta1+\omegag,12*x1
\eta2+\omegag,22*x2
Then solving them I get (I think):
x1=A1cos(\omegag,1+\phi1)
x2=A2cos(\omegag,2+\phi2)
That looks good.
So then:
\eta1+\omegag,12*x1
\eta2+\omegag,22*x2
I don't follow what you did there.
In a normal mode, both particles will have the same frequency. That is, you should have
x1=A1cos(\omegat+\phi1)
x2=A2cos(\omegat+\phi2)
with the same value of ##\omega## for both particles. You need to substitute these expressions into your differential equations.
Maybe I'm missing the concept then. I don't really understand why they'd have the same frequency. If one mass is heavier than the other wouldn't it have a lower frequency?
It's essentially part of the definition of "normal mode" that each particle has the same frequency. See:
http://en.wikipedia.org/wiki/Normal_mode.
Also, in a normal mode, the particles move either "in phase" with each other or "out of phase" with each other. This mean that you can assume that the phase constant ##\phi## is the same for each particle. "Out of phase" then means that A1 and A2 will have opposite signs. In finding the normal modes, you can actually just let ##\phi = 0##.
So, you can make the assumption that the motion of each particle is described by
x1=A1cos(\omegat)
x2=A2cos(\omegat)
If you sub these into your two equations of motion, you will be able to determine the possible normal mode frequencies and whether the particles move in phase or out of phase in each mode.
[EDIT: You can explore the normal modes of a similar system here: http://www.falstad.com/coupled/
You can change to 2 masses and you can vary the individual masses (click on "mouse:pull string"). You can select either normal mode or a combination of the modes (slide the two dots near the middle left side of the screen).]
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
