Solving for Parallel Tangent Lines: A Confusing Example
To find the point on the curve y = 1 + 2e^x - 3x where the tangent line is parallel to the line 3x - y = 5, the slope of the line is determined to be 3. The derivative of the curve is calculated as y' = 2e^x - 3. Setting this equal to the slope of the line gives the equation 2e^x - 3 = 3, leading to x = ln(3). The corresponding point on the curve is confirmed to be (ln(3), 7 - 3ln(3)). Graphical representation is suggested for better understanding.
zenity
I'm kinda stuck on this question... my text gives me a simple example, but it's far from enlightening. Just wondered if I could get some help!
"At what point on the curve y = 1 + 2e^x - 3x is the tangent line parallel to the line 3x -y =5?"
Would I just need to simply compare the slopes?
I found the derivative of the curve: y'= 2e^x - 3
So I suppose you just set 2e^x = 3... then you get x = ln(3)/2 ?
Thanks~
parallel means same slope, so u found \frac{dy}{dx} = 2e^x - 3
y=-5+3x, \frac{dy}{dx} = 3
3 = 2e^x - 3
3 = e^x
ln(3) = x
Oh, so I had to compute the derivatives for both slopes, then compare them? Interesting... thanks! I have to digest this info now.
-------> Should be -----> 2e^x - 3 = 3 -----------> x = ln(3)
Thanks~
zenity --
Your original approach was CORRECT. You just made the careless error shown above. Method is to determine slope of the line (compute dy/dx of the line OR determine by inspection (like you did) from the line's {y = mx + b} equation that the slope is "3") and then to equate this value to the curve's tangent slope (found by differentiating the curve's equation like you did).
so the point would be... ( ln(3), 7-3ln(3) ) ?
I'm just a bit confused graphically.
zenity said:
so the point would be... ( ln(3), 7-3ln(3) ) ? <----- CORRECT
Your answer is CORRECT. If helpful, sketch the graph to better understand the math. (Or use a graphing calculator.)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
