Solving for Stress and Strain in Three Dimensions
The discussion focuses on solving a system of equations relating stress and strain in isotropic materials. The equations provided describe how stress components (\sigma_{xx}, \sigma_{yy}, \sigma_{zz}) relate to strain components (\varepsilon_{xx}, \varepsilon_{yy}, \varepsilon_{zz}). A participant initially attempted to solve the equations using matrix row reduction but encountered difficulties, leading to a request for alternative methods, such as Cramer's Rule. Another participant suggested simplifying the problem by adding the equations together to derive a relationship for the sum of strain components. Ultimately, the original poster successfully solved the problem using the method of determinants and cofactors after receiving guidance.
KEØM
Knowing that the stress and strain for an isotropic media can be related with the following expressions:
\sigma_{xx} = (\lambda + 2\mu)\varepsilon_{xx} + \lambda\varepsilon_{yy} + \lambda\varepsilon_{zz}
\sigma_{yy} = \lambda\varepsilon_{xx} + (\lambda + 2\mu)\varepsilon_{yy}) + \lambda\varepsilon_{zz}
\sigma_{zz} =\varepsilon_{xx}\lambda+ \lambda\varepsilon_{yy} + (\lambda + 2\mu)\varepsilon_{zz}
Solve this system of equations for the three strain components to derive that:
\varepsilon_{xx} = \frac{2(\lambda + \mu)\sigma_{xx} - \lambda(\sigma_{yy} + \sigma_{zz})}{2\mu(3\lambda + 2\mu)}
\varepsilon_{yy} = \frac{2(\lambda + \mu)\sigma_{yy} - \lambda(\sigma_{xx} + \sigma_{zz})}{2\mu(3\lambda + 2\mu)}
\varepsilon_{zz} = \frac{2(\lambda + \mu)\sigma_{xx} - \lambda(\sigma_{xx} + \sigma_{yy})}{2\mu(3\lambda + 2\mu)}
\sigma_{xx} = (\lambda + 2\mu)(\varepsilon_{xx}) + \lambda\varepsilon_{yy} + \lambda\varepsilon_{zz}
\sigma_{yy} = \lambda\varepsilon_{xx} + (\lambda + 2\mu)(\varepsilon_{yy}) + \lambda\varepsilon_{zz}
\sigma_{zz} =(\varepsilon_{xx}) + \lambda\varepsilon_{yy} + (\lambda + 2\mu)\varepsilon_{zz}
\sigma_{ij} = \lambda\delta{ij}\varepsilon_{kk} + 2\mu\varepsilon{ij}
Hint: \sigma_{xx} = \sigma_{yy} due to symmetry.
Well I put the three equations into matrix and tried to carry out row reduction and I came up with the following result:
<br /> \left[<br /> \begin{array}{c}<br /> \sigma_{xx} \\<br /> \sigma_{yy} \\<br /> \sigma_{zz}<br /> \end{array}<br /> \right]<br /> <br /> =<br /> <br /> <br /> \left[<br /> \begin{array}{ccc}<br /> \lambda + 2\mu &amp; \lambda &amp; \lambda \\<br /> \lambda &amp; \lambda + 2\mu &amp; \lambda \\<br /> \lambda &amp; \lambda &amp; \lambda + 2\mu \\<br /> \end{array}<br /> \right]<br /> \left[<br /> \begin{array}{c}<br /> \varepsilon_{xx} \\<br /> \varepsilon_{yy} \\<br /> \varepsilon_{zz}<br /> \end{array}<br /> \right]<br />
I firstly attempted to remove the terms in the first column and the second and third rows, I did this by multiplying the top row by \frac{\lambda}{\lambda + 2\mu} and subtracting that from the second and third rows which gave me the following matrix:
<br /> <br /> = \left[<br /> \begin{array}{ccc}<br /> \lambda + 2\mu &amp; \lambda &amp; \lambda \\<br /> 0 &amp; \lambda + 2\mu - \frac{\lambda^2}{\lambda + 2\mu} &amp; \lambda - \frac{\lambda^2}{\lambda + 2\mu} \\<br /> 0 &amp; \lambda - \frac{\lambda^2}{\lambda + 2\mu} &amp; \lambda + 2\mu - \frac{\lambda^2}{\lambda + 2\mu}<br /> \end{array}<br /> \right]<br />
In order to get rid of the term in the second column and the third row, I multiplied the second row by \frac{\lambda(\lambda + 2\mu) - \lambda^2}{(\lambda + 2\mu)^2 - \lambda^2} and subtracted that row from the third row. This gave me the following matrix:
<br /> <br /> = \left[<br /> \begin{array}{ccc}<br /> \lambda + 2\mu &amp; \lambda &amp; \lambda \\<br /> 0 &amp; \lambda + 2\mu - \frac{\lambda^2}{\lambda + 2\mu} &amp; \lambda - \frac{\lambda^2}{\lambda + 2\mu} \\<br /> 0 &amp; 0 &amp; \frac{(\lambda(\lambda + 2\mu) - \lambda^2)^2}{(\lambda + 2\mu)((\lambda + 2\mu)^2 - \lambda^2)} - \left(\lambda + 2\mu - \frac{\lambda^2}{\lambda + 2\mu}\right)<br /> \end{array}<br /> \right]<br />
Therefore I can write my first solution out as:
\sigma_{zz} = \left(\frac{(\lambda(\lambda + 2\mu) - \lambda^2)^2}{(\lambda + 2\mu)((\lambda + 2\mu)^2 - \lambda^2)} - \left(\lambda + 2\mu - \frac{\lambda^2}{\lambda + 2\mu}\right)\right)\varepsilon_{zz}
which doesn't appear to be right. It would be of much help if someone could show me an easier method. Perhaps Kramer's Rule but I am unfamiliar with that method. Any help will be greatly appreciated.
Thank you,
KEØM
You haven't performed all the algebra you can on the coefficient of epsilon-zz. I would get a common denominator and add the two terms together to see if further simplification results.
Cramer's rule is fairly easy to remember. I am surprised you haven't com across it. It's the one where you compute all of the determinants and solve for the unknowns.
http://en.wikipedia.org/wiki/Cramer's_rule
Thank you for your help steamengine, I was able to solve the problem by finding the inverse matrix using the method of determinants and cofactors. Thanks again for your reply.
In your first attempt, you forgot to apply the operations to the left-hand sides of the equations. When you do something to the right hand side of an equation, you need to do the same thing to the left hand side.
For this particular set of 3 simultaneous linear equations, there is a simple trick for solving for the three strains. Just add the three equations together, to get:
(\sigma_{xx}+\sigma_{yy}+\sigma_{zz})=(3\lambda+2\mu)(\epsilon_{xx}+\epsilon_{yy}+\epsilon_{zz})
or
(\epsilon_{xx}+\epsilon_{yy}+\epsilon_{zz})=\frac{(\sigma_{xx}+\sigma_{yy}+\sigma_{zz})}{(3\lambda+2\mu)}
Then, rewrite the first equation as:
\sigma_{xx}=\lambda (\epsilon_{xx}+\epsilon_{yy}+\epsilon_{zz})+2\mu \epsilon_{xx}=\lambda \frac{(\sigma_{xx}+\sigma_{yy}+\sigma_{zz})}{(3\lambda+2\mu)}+2\mu \epsilon_{xx}
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
