Solving for Time: Dropped Pop Can Reaches the Ground
  • Thread starter Thread starter powerxranger1
    Ground Time
A hot air balloon rises at a constant velocity of 4 m/s before a can of pop is dropped from a height of 4 m. The initial velocity of the can is 4 m/s upwards, and it experiences free fall with an acceleration of 9.8 m/s² downwards. The correct approach to determine the time it takes for the can to reach the ground involves using kinematic equations while paying attention to the signs of the values. Initial calculations suggesting a time of 2 seconds were incorrect due to misunderstanding the final velocity and acceleration. Properly applying the kinematic equations will yield the accurate time for the can's descent.
powerxranger1
A hot air balloon is rising upward with a constant velocity of 4m/s. As the balloon reaches a height of 4m above the ground the balloonist accidently drops a can of pop over the edge of the basket. How long does it take the pop can to reach the ground?
V2 = 4m/s [up]
v1 = 0
d = 4m
d=1/2 (v2 + v1) t
I got the anser 2 seconds! Please tell me if i did it correctly
Hi powerxranger1,
V2 = 4m/s [up]
v1 = 0
d = 4m
d=1/2 (v2 + v1) t
No, I don't believe that's right. The initial velocity of the can is 4m/s upwards, like you have, but the final velocity is not given. (The final velocity in this case would be the velocity just before the can touches the ground, so it would not be zero.)
So you know the initial velocity and the displacement (but check the signs!); what else do you know about the can's motion? That will help you choose the best kinematic equation to find the time.
Hm, I'm not really sure that there is any other information given about the can, since there's only two numbers given. I don't understand how to find another piece of information.
The can is in free fall; what does that tell you? That will give you the third quantity, and so you can find the time.
Oh. Does that mean it's just 9.8 m/s?
Yes, that's the right magnitude for the acceleration. (And the units are m/s^2.) Just remember to use the correct signs for the initial velocity, displacement and acceleration when you use them in your equation.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
