Solving for Work: 14,500J Applied to 1.2m Crowbar
Applying 14,500 J of work to a 1.2 m crowbar raises questions about the output work produced. The initial calculation attempts to multiply the work and distance, resulting in incorrect units (J m) rather than proper work units. The discussion emphasizes the principle of conservation of energy, suggesting that the output work should equal the input if no energy is lost to friction or other factors. Ultimately, the output work can be considered equal to the input work under these ideal conditions. This highlights the importance of understanding work and energy principles in physics.
NatalieWise123
You apply 14,500 J of work to one end of a crowbar. If the crowbar is 1.2 m long, how much work is produced by the crowbar? (friction is not a factor)
Work=distance*force
There's hardly any information in this question so the only thing I can think to do is multiply the two numbers. That would give you 1.74 x 104 J which would make the output greater than the input which isn't allowed, right?[/B]
No, that would give 1.74 x 104 J m, which are not proper units for work.
Conservation of energy is indeed a good place to start.
would the output just be equal to the input then?
Yes, if you can neglect any work done on the crowbar itself.
Likes NatalieWise123
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
