Solving Force vs Time Graphs: Velocity Example #37
To solve for velocity from a force versus time graph, the impulse (ΔP) is determined by calculating the area under the curve. The confusion arises from discrepancies in the impulse calculation, leading to doubts about the provided answer of -1 m/s. To find the correct velocity, one can use the relationship F=ma to calculate acceleration, then apply kinematic equations. Starting with an initial velocity (Vi) of 0 and a time duration of 20 seconds, the final velocity (Vf) can be derived using the formula Vf = Vi + at. Clarifying these steps can help resolve the confusion surrounding the problem.
kk727
I was given this worksheet today:
http://www.mrwaynesclass.com/impulse/WS/momentum.pdf
However, I was not in school today nor when we started momentum. So I'm a little confused with the graphs. On a force versus time graph, how do you go about solving for velocity? An example problem would be #37. They give you the answer to be -1 m/s (answers are at the bottom) but how do you get there?
P=mv
ΔP/ΔT = F
F=ma
I figured that impulse (ΔP) would be area under the curve, so I calculated that. But using the force and time on the graph, the impulse didn't match up and I just got all confused and frustrated. Can anyone help?
I just realized that the worksheet has two problems that are #37... -_- So I'm doubting that -1 m/s is the answer to this one. I'm still confused with trying to solve it, though!
There is no way it's -1...
Try doing this:
Using F=ma, you can get the acceleration, right? With the acceleration you can use the kinematics equations to get the answer.
You have:
Vi = 0
Acceleration = You find it
Time = 20 s
Vf = ? (solve)
So you can use:
vf = vi + at
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
