Solving Friction & Force Problems with Physics Formulas
  • Thread starter Thread starter mrs. drake
    Force Friction
To determine the coefficient of friction between the turkey and the snow, the formula FF = u * FN can be applied, where FN is the normal force. After a collision with a force of 890N, the acceleration of the turkey can be calculated using Newton's second law. When the turkey slides onto a frictionless road with a 4% grade, the acceleration and final speed can be derived from the forces acting on it over a distance of 100m. Additionally, in the shoving match scenario, Garfield's acceleration can be calculated using the mass and acceleration of Felix, confirming that the problems are interconnected. Understanding these physics principles is essential for solving friction and force problems effectively.
mrs. drake
1) I was dragging my frozen 7.2kg turkey due north through the snow at a constant velocity of 2m/s while exerting a horizontal force of only 5.3N.
What was the coefficient of friction between the frozen turkey and the snow?
don't you use the formula " FF=ufn" u=coefficient
then mk=ff/fn ?
2) Just when I was almost to the door, my son came sliding into the turkey from the east. He crashed into the turkey with a force of 890N.
What was the magnitude and direction of the acceleration of the turkey after the collision?
3) The turkey slid at 2m/s into the icy, frictionless road in front of our home, which is a gentle hill of about 4% grade. I was wondering how fast the turkey would be going when it got to the bottom of the hill, 100m away.
Calculate the x and y components of the forces acting on the turkey?
What was the acceleration of the turkey on the road?
how fast was the turkey going when it going when it got to the bottom of the hill?
4) Garfield, who has a mass of 25.0 kg, and the 20.2kg felix, get into a shoving match over who is the cooler cartoon feline. Garfield caused felix to accelerate away at 3.01m/s^2.
Find the magnitude of the acceleration of Garfield away from felix.
don't you use the formula ma=ma.
therefore i got 2.7
do i need answers from like #1 to do #2 and so on?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
