Solving Laplace Transform for t-tU(t-1)
jtruth914
I attached the problem as a word document. I'm stuck trying to determine the laplace transform for t-tU(t-1). I know I'm supposed to work with 1/s^2(s+2) and solve for A, B,C. I got B=1/2, A=-1/4, and C=1/4 when 1=(As+B)(s+2)+Cs^2. The answer to the problem is
y= 1/4 + 1/2t +1/4 e^-2t -[1/4 +1/2(t-1) -1/4 e^-2(t-1)] U(t-1). I understand where 1/4 + 1/2t +1/4 e^-2t comes from but I don't understand where -[1/4 +1/2(t-1) -1/4 e^-2(t-1)] U(t-1) comes from.
You are trying to find the Laplace transform for f(t)= t for t \le 1, f(t)= 0 for t>1?
I would just use the definition of "Laplace transform":
\int_0^\infty f(t)e^{-st}dt= \int_0^1 te^{-st}dt
Integrate that "by parts". Let u= t, dv= e^{-st}dt, du= dt, v= -(1/s)e^{-st} so this is
\left[-(t/s)e^{-st}\right]_0^1+ (1/s)\int e^{-st}dt= -e^{-s}/s+ \left[(-1/s^2)e^{-st}\right]_0^1
= -e^{-s}/s- e^{-s}/s^2+ 1/s^2
I still don't understand where -[1/4 +1/2(t-1) -1/4 e^-2(t-1)] U(t-1) comes from. The answer is y= 1/4 + 1/2t +1/4 e^-2t -[1/4 +1/2(t-1) -1/4 e^-2(t-1)] U(t-1). Where does the second part of the answer come from.
Do you not know what "U(t-1)" means? U(t), the Heaviside function or "unit step function" is 0 for x< 0, 1 for x> 0 (generally it is defined to be 1 at x= 1 but that is not important). The "t- 1" argument just shifst the step to x= 1: when x= 1, x- 1= 0 so U(1-1)= U(0). That is, U(t- 1) is 0 for x< 1, 1 for x> 1.
If x< 1 then -[1/4 +1/2(t-1) -1/4 e^-2(t-1)] U(t-1)= -[1/4+ (1/2)(t- 1)]+ 1/4e^{-2(t-1)}(0)= -1/4- (1/2)t- 1/2= -[(1/2)t+ 3/4]. If x\ge 1, this is -[1/4+ (1/2)(t- 1)]+ 1/4e^{-2(t-1)}(1)= -[(1/2)t+ 3/4- 1/4e^{-2(t-1)}]
When the author writes ##t - t u(t-1)## he/she is essentially saying that
\int_0^1 e^{-st} t \, dt = \int_0^{\infty} e^{-st} t \, dt - \int_1^{\infty} e^{-st} t \, dt. You could put ##t = x+1## in the second term to get
\int_1^{\infty} e^{-st} t \, dt= \int_0^{\infty} (x+1) e^{-s(x+1)} \, dx
and then do the integral on the right as a sum of two already-known integrals.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
