MHB Solving Mechanics Problem: Friction, 2 Boys, Toy Acceleration
The discussion revolves around a mechanics problem involving two boys pulling a toy with different forces and angles on a rough surface. The toy has a mass of 3kg and a coefficient of friction of 0.3. Calculations show that the acceleration of the toy is 0.178 m/s², with the direction of acceleration favoring the younger boy's pull. The friction force acts opposite to the direction of motion, confirming that the younger boy's force overcomes the older boy's pull. The conclusion is that the toy moves in the direction of the younger boy’s pull.
Shah 72
MHB
Two boys are arguing over who gets to play with a toy. The toy has mass 3kg and is at rest on rough horizontal ground with coefficient of friction 0.3. The older boy pulls with a force of 26N at an angle of 39 degree above the horizontal. The younger boy pulls in the opposite direction with a force of 24N at an angle of 9 degree above the horizontal. Determine whether the toy moves. If it accelerates find the size of the acceleration and direction.
Iam able to solve this.
I got a= 0.178m/s^2. What iam not able to reason is the direction of acceleration. Pls help
Mathematics news on Phys.org
in this case, friction acts opposite to the direction of motion … who wins?
You mean the acceleration is positive so the friction acts in the opposite direction which is the young boy?
acceleration is in the direction of the young boy’s pull …
$24\cos(9) > 26\cos(39) + 0.3[3g - 24\sin(9) - 26\sin(39)]$
Thank you so much!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
