Solving Orbital Radius Problem: Reduce Radius by 1.09 km
  • Thread starter Thread starter jbot2222
    Orbital Radius
The discussion centers on solving a physics problem involving an astronaut in a space shuttle trying to catch up to a satellite by reducing their orbital radius by 1.09 km. Participants suggest equating gravitational force with centripetal force to determine angular velocity, noting that both the shuttle and satellite share the same angular velocity. The difference in speed due to the radius change is crucial for calculating the time it will take to reach the satellite. One user expresses confusion over their calculations and seeks clarification on the numerical values obtained by others. The conversation highlights the complexities of orbital mechanics and the importance of accurate calculations in such scenarios.
jbot2222
im not getting this problem AT ALL:
You are an astronaut in the space shuttle pursuing a satellite in need of repair. You find yourself in a circular orbit of the same radius as the satellite, but 30.7 km behind it. How long will it take to reach the satellite if you reduce your orbital radius by 1.09 km? You can assume the space shuttle has an orbit of 200 miles above the Earth's surface.
Equate the gravitational force with the centripetal one and from there u should be able to find the angular velocity.
The speed difference between the shuttle and the satellite will result simply from the fact that both the shuttle and the satellite would move with the same angular velocity.
With the distance and the difference in speed,u should be able to find the time.
Daniel.
i tried it, but I am getting the wrong answer. wat numerical value did u get when u did it?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
