Solving Rectilinear Motion: Find Velocity & Position
The discussion focuses on solving for the velocity and position of a particle under a specific force function, F=Fosin(ct), starting from rest. The participant derives the acceleration and integrates to find velocity and position functions, initially arriving at incorrect expressions. After reviewing the solutions manual, they realize the correct velocity is v=(Fo/cm)(1-cos(ct)) and the position is x=(Fo/mc^2)(ct-sin(ct)). The participant acknowledges the need to ensure the particle is at rest at t=0 for accurate results. This highlights the importance of initial conditions in solving rectilinear motion problems.
Find velocity and position as functions of time t for a particle of mass m, which starts from rest at x=t=0, subject to the following force functions.
a) F=Fosin(ct)
F=ma
a) a=Fosin(ct)/m
dv/dt = Fosin(ct)/m
∫dv = ∫Fosin(ct)/m dt
v = -Fo(cos(ct))/mc
integrate again
x+ Fo(sin(ct))/(mc^2)
This solutions manual says the answer is
v=(Fo/cm)(1-cos(ct)
Look at your expression for v(t), remember that you want it to be at rest at t=0.
I understand now, thanks
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
