Solving sqrt (Y+6) - sqrt (3y) = 3
  • Thread starter Thread starter perpetual-burn
To solve the equation sqrt(Y+6) - sqrt(3y) = 3, it is necessary to square both sides of the equation twice. The first squaring isolates one square root, leading to the equation y + 6 + 3y - 2sqrt((y+6)(3y)) = 9. After isolating the remaining square root, squaring again will yield a quadratic equation. It is important to check that the solutions obtained are greater than zero to ensure they are valid. This method will help in accurately completing the homework.
perpetual-burn
Hey guys,
I was wondering how to solve this equation. I tihnk I got it, but I want to make sure so I don't go on doing all of my homework wrong.
Question: sqrt (Y+6) - sqrt (3y) = 3
I forget if I have to sqaure each separate or the whole left side as FOIL. Please let me knwo asap so I can finish homeowkr :) Again, thanks so much!
-Phil
U'll have to square twice.And each time separate a sqrt in one side of the equation.
\sqrt{y+6}-\sqrt{3y}=3\Rightarrow y+6+3y-2\sqrt{\left(y+6\right)3y}=9
and then isolate in one member of the equation that sqrt and then square again.
Daniel.
Ok, waht i tohught :) Thanks Dan.
I hope u can solve the quadratic that will follow.And to check whether the solutions u get are larger than 0...
Daniel.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
