Python Solving UnboundLocalError for Python Iterative Deepening Depth First Search
The discussion centers around an implementation of iterative deepening depth-first search (IDDFS) in Python, using a graph represented as a dictionary. The code attempts to find a goal node ('31') starting from a given node ('7') while adhering to a specified depth limit. Key issues highlighted include confusion regarding the implementation and a specific error related to the depth variable, which is not properly defined or incremented within the IDDFS function. The importance of correctly managing the depth variable is emphasized, as it is crucial for the algorithm's operation. Additionally, there are references to various pseudocode resources that may aid in understanding the algorithm better. Overall, the thread reflects challenges in coding and debugging the IDDFS algorithm effectively.
shivajikobardan
This code is for iterative deepening depth first search in python.
Code:
# Python dictionary to act as an adjacency list
graph = {
  '7' : ['19','21', '14'],
  '19': ['1', '12', '31'],
  '21': [],
  '14': ['23', '6'],
  '1' : [],
  '12': [],
  '31': [],
  '23': [],
  '6' : []
visited=[]
goal='31'
depth=0
depth_limit=2
def dls(visited, graph, node,depth_limit):
    if(node==goal):
            print("goal found")
            return True
    if(depth>=0):
        #to print path
        if node not in visited:
            visited.append(node)
        for neighbor in graph[node]:
            dls(visited, graph, neighbor,depth_limit-1)
    return Falsedef iddfs(visited,graph,node):
    while True:
        solution=dls(visited,graph,node,depth_limit)
        if(solution==goal):
            print("Success goal find at depth=",depth)
            print("Path=",visited)
        depth=depth+1
print("Following is the Depth-First Search")
iddfs(visited, graph, '7')
There are various pseudocodes available for this problem. They are as follows-:
I did my best to understand and implement the code but I seem to have failed. And it is getting really confusing. Can you help me?
https://lh3.googleusercontent.com/bCcAVC07nNgvg_rfn7GoSiplk5aMf8pjnKSak49QpnowIVbRu4gaemAgrwNgQJWctqw_lT1SqDneYntHVeWx04Jn8SKnn_svfRWVe5N267NeoO_rHZrMBa8OA4MlTYtDqZVLmDZv
https://lh6.googleusercontent.com/y0ALu9o9XvnLNTx0x-XvD02_vtgeURoMqfXM09vHIT50pbADwsQkqwSy55sUkLopSBKA_8L0b1xhJFcZgDgXyMKQAsy146aRIyaCGW-ofUtvwByjkUyGstnj9x0QJBITXyNRQdh6
https://lh5.googleusercontent.com/piadg7lpiYBSIlFzCkaRez9J1vSDkNU5nm0dOCBg4VtZwN9236Tn09V4-EJSHajc5tL64FNsrzhHJURHd6Y9lVefN0uhp8K5fzG7r3cHj6gV-BnzwOt2r5OW22AIFUZ36lSvy_qd
https://lh5.googleusercontent.com/3gsZwrM-eO_9PRtTPNmAWdD50E7lqwSzg81AJi8dFoisgZQA2ShmchSmGzY91O_2Gko6R-ed9R4XAw_cJ7egzBS6IF2aIaR_cQMWJq6SbVVd7bJDDYyRTLslBMzYF5gxe5z6qAMQ
https://lh4.googleusercontent.com/6rTwnJ9B5byKb_ygzpMMKwifdLUA4nQu4heJnRwVKOrxBOL3m-FoowraATMDnIM3vOzu6TgFPj8jYGQTb6sE7bDoWpfL27TC35nCGUfxjZ73Tu_Gm6iqHcx15JgTJFPyNvlWtXue
https://lh4.googleusercontent.com/zKLSsd5FTjVBbNpgUPZKfUiBmv9lIRKS28cFh5OIrV0KSaPziejmnufEWAMojmKcChsxsJ4v6o4wXGVwdptKd2eaIIpoKpCw0MO2YoN74quEG3nXGSGLA7KZuumSZSQ8pNxKxuXi
https://lh6.googleusercontent.com/P-enAU6E3tyZarmyp3mFlyts6h4gxUsK9RgwrsT18vzRymmvYKE1e4XXguiismIjS4PXMNyPyQDy8LwJ0MRlg4ssO3bK2FRpqNn_WAijet0HUZk2--YjO_5wHegsHA5WGl7NNGVG
https://lh3.googleusercontent.com/-CZvA8uUDNJ5T2a-WowcEAWj_5VEPQM20AV8s-GhkXckDN_rIOHuIfDoPa2Xlaur6fpc-iOJCK5Ie4H36IutVY60hNRyR6hIxqtpPBnyzP009UWOKfH80-XWFPx37hKoVry0Xbb-
https://lh6.googleusercontent.com/Iwi51k435c6g0HLrgvpSZM3RnoXFg5q9yrCEyPmhLMuoWAECXB2uDudITh8pcvouy_pc7Myn49thlWd4X_N2iGuQBXjIkKCMtEbjlxk8_jYDwfdvfgsfYOVVP88o-9FqM5mXkuqn
https://lh5.googleusercontent.com/PvBSa_J0ydYpDcrB6hZEy8vfomG7OrO-zECB64uFOn8lXp61Wl4H2ydGTquUu0EPSy5m95sGlGwXjKIB_ZkvfyIcGM4EoHitCnm_4NzygFWTE4RDXixnUZcLLzjy00FSExNjylzl
https://lh6.googleusercontent.com/9im-1q9yA18GyyRTNN6YR8KHdcSZeXjl97qhPpey1fT-CnjbPUTeHbzpNvp2BCusUXP3BZdNSJ_qIlv0I-1tr7mb7KsgHTDtebTxSmSzJWyQWI3IVBpZuZ1q6u7XPTMpMGqILJGd
https://lh6.googleusercontent.com/FDsphRKkKZnk9IrNDub0OM37r99PrQadZCtQ0ng57wW5AgmfeGDumw4U8cwQ8OxXYsamOutNeiE9VnMnOjAwv7L-LMt0D_HfXM1m_tJlzL8RumLcoEhUnbd-OH4UtwxVHaSbuBeU
https://lh6.googleusercontent.com/qQid6vyarXpvGZz_h3NDgi51xya-bApAMFLHJf_w232RJ_6ynadW22KTYGjMOJUr3FkVykrtIRrtGa-7dphrz8VfFqCgCoSbnNtfco7zU-8d-2wQquG_L_UE4A8G7wg0DIYq57i9
https://lh6.googleusercontent.com/VqD2_ogLHtT739zeBA1-xbc-eKFHOt5B00aLMfP64nvZDiyjncToZZaotOshLKMU4TndOGiH3c26A-yORC4pR3HONDFVp9-IJS6iAWQzDJjXJu4hh20Le53nAsSizUnxll92KbB8
https://lh3.googleusercontent.com/_5QbqLz94Nj3F7gUoTo7DwyNsY2TFdSWN3xEs04CjXfDDfRgmDPPz7VxOTpThu4ibQcllX53b7UaC_rpNPiof9z-sLDPD7CT8p44vgkjTs-hDnfupFfq10yGVXVRII89jcEndWZ1
Technology news on Phys.org
This function has an issue:
Code:
    while True:
        if(solution==goal):
        depth=depth+1
When you reference depth here in the last line, that causes the error. There is no input of depth or creation of a depth variable, so it doesn't exist inside the function and you can't increment it.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
